I had that issue because of bad drivers. Try different ones.
Hi guys,
I hope you can help me on this.
The touchscreen worked for 2 weeks then I took the computer in to debug it for about 3-4 days, from then on the touchscreen stopped working.
I was able to install the driver and the touchkit software for it and the software recognizes my controller but I am not able to calibrate the touchscreen. I'm running a fresh installation copy of Windows XP SP2. Everything seems to be fine except calibrating the touchscreen. Anyone have any suggestions that I can do to correct this?
Andrew
08 Lincoln Navigator www.mobiteklink.com
I have tried both the ones that came with the LCD and also the one from eGalax (link below)
http://www.eeti.com.tw/web20/eg/drivers.htm
Can you tell me which version you use?
There's 4.021929, the most current build is 4.373215 ;
