Results 1 to 10 of 11
Thread: buy Lilliput GL701?
    Low Bitrate mrborrie's Avatar
    Jan 2006
    Netherlands
    buy Lilliput GL701?
    I can get my hands on a Lilliput GL701.
    radio has a problem that it wont go louder than 1 (might me possible to replace the button i dont know)
    anyways its about 200 euro's. i have read allot about the display sucking balls but it a nice solution no to destroy my dashboard.
    All in all do you think 200 is a good price for this display? or just keep away from it on any price. Thanks
    Jan 2006
    Netherlands
    Can get it for €175 ill guess ill go for it. not bad for a 7inch touchscreen anyway
    Aug 2006
    Honestly - I would say don't buy one for any price..
    I have one and your right, the display sucks big time - I have seen mirrors less reflective than this thing!
    That and the fact that its build quality is absolute rubbish... the only good thing I can say about it is that my replacement screen from Lilliput has not failed (yet..) been going for 5 months now! I think thats quite an achievement for a Lilli
    Jan 2006
    Netherlands
    Hi thanks for the reply,
    I can now get if for 175 and that’s not expensive for a 7inch touch anyways.
    and i dont feel like taking my dash apart right now so I am probably stupid but im going to give it a try.
    Already made a post for the problem it has.. ill keep you guys updated on my silly decision
    Aug 2006
    Hehe, ok well if you do get it here is some advice:
    - Keep the lilli below a volume of around 31.. it hisses like a ***** anything over that.
    - Don't let any force touch the screen or have it pressing against anything - the motor gears are weak!
    - Make sure you have a good ground, its very prone to interference
    - Try to position the unit out of direct light, as the screen is VERY reflective
    - If you have a wobbly/waving picture then play with the barrel connector (connects the unit to the RCA, VGA etc..) they are not a good fit and need to fiddling to get a decent picture.
    Mar 2006
    Colorado, but Canadian!
    You asked for opinions, yet you ignore the opinion you got. hmmmm.
    Well I say no aswell. 175E is on the cheap side of things, but when it has a problem like that, the value goes into the toilet. You can get a brand new double din for $200USD which is about equal. Second hand ebay I am sure you can find one that works and for the same price if you wanted motorized.
    Personally I say stay away from the motorized. It is not a question of if it will fail, rather a question of when will it fail.
    And then you have a piece of garbage. So if you absolutely must go single din, then get a non-motorized. Else, try and get a friend of yours that is good with fabrication to put a real screen in/
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2006
    Netherlands
    i have to agree with you, but the other options do not have a radio inside of the unit.. ill reconsider but its so appealing still knowing the unit sucks balls..
    Newbie onada's Avatar
    Apr 2006
    Canada
    I just purchased this one as well Gl701/NP/C/T. I got it for 200$ CND Brand New (180$ US) . I was planning to get the regular lilliput EBY701 but got this for same price ( I was planning fabrication , fiberglass)
    I was wondering in case the moror failed, or just found too much problems with added on opftions ( radio, tv, motor...etc) can I still take it apart like the regular EBY701 and just use the screen, or is it a little bit more tricky?
    Thanks!
    May 2005
    Toronto, ON
    Quote Originally Posted by onada View Post
    Thanks!
    Where'd you find it that cheap??
    You can take it apart, but there's some work involved. You can always find replacement parts from Lilliput directly. I got some replacements for my broken gears.
    Jun 2007
    Cincinnati
    I just Bought a brand new lilliput 701GL off ebay the seller said it was the newest model and the old problems were fixed but I paid 400usd after shipping I got it and installed it and then It wouldn't power on so I sent it back to him and he is supposed to be sending me another
  1. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  2. Closed - Lilliput 7" XGA Touchscreen GROUP BUY
    By imi1232000 in forum Classified Archive
    Last Post: 04-14-2004, 11:29 PM
  3. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  4. Vote for a Money Order Lilliput Group Buy
    By NightHunter in forum LCD/Display
    Last Post: 03-19-2004, 06:34 PM
