Results 1 to 6 of 6
Thread: Xenarc Power
    Jul 2001
    Dallas, TX
    Xenarc Power
    So has anyone come to a conclusion on powering the Xenarc in the car? Is it safe to use the vehicles 12v considering it's rated between 10-36v@1amp. Or is it better to use a pc's PS?
    Brian Cozzens
    Duke Nukem Forever / Max Payne
    www.3drealms.com
    Feb 2002
    I've been using the car 12V adaptor for a month. Hasn't caused a problem yet. Now, if I could only force my xenarc to turn itself on when it is given power...
    Jul 2001
    Dallas, TX
    ahhh, excellent. So did you splice the AC power supply and just run it to the cars 12v, or didja buy a generic 12v adapter+plug from radio shack or whatever?
    Having the display come on when power is given to it would be wonderful, I keep hoping somebody is gonna come up with a simple circuit to throw a pulse at that sucker
    Brian Cozzens
    www.3drealms.com
    May 2002
    Gorge of eternal peril
    Be warned:
    Originally posted by cng1
    CRAP! Something has gone REALLY wrong!
    The thing (reffering to his Xenarc monitor) was working on my home PC, through the wall outlet.
    I take it outside and splice the power cord and run it inline with my power inverter's power/ground wires. PC in car comes on fine but no power to TV. Hmmmm, i take it back inside and wire the AC cord back to normal and it doesn't work INSIDE now!!! No power at all!!!!! Any ideas? I didn't think anything I did could've broken/fried it..... CRAP!
    thanks,
    Clayton
    Rest of the thread here:
    '03 BMW M3 6 spd.
    Black/Imola Red
    19's
    Shuttle XPC w/ AMD 1800+
    Opus 150w
    Lilliput 7"
    Wireless internet through my P900 and bluetooth
    Jun 2002
    That's exactly why you run it off of the computer's power supply- It provides a true (or close enough) 12v source. A car can provide anything between 12-14vdc. Just because it hasn't happened yet doesn't mean it won't. Kind of a risky move with a $500 investment.
    Jul 2002
    Downey, California
    The display is rated for a wide range of voltage. I don't have mine in front of me right now, but I think it went higher than 18V. Which would be fine for vehicle use.
    I don't see any damage occuring from the voltage going to low, as the internal regulator would just brown out, so there is no worry about the vehicle power going below the recommended minimum.
    It should be perfectly safe to run a FUSED line from your vehicles power, but be warned, DO NOT CROSS THE POSITIVE AND NEGATIVE LINES. You will fry it. As was deemed the case in that post referenced above by InFix.
    [------------------|--] 90% Completed
    Not installed, yet.
    Developing Completely DirectX shell.
    P4 1.7GHz, 256MB RAM, 40GB-7200RPM HD
