Results 1 to 8 of 8
Thread: Lilliput Touchscreen Inverted
    Jan 2007
    After installing my touchscreen drivers for my 7" Lilliput widescreen, the touchscreen options seem to be inverted. If I touch the bottom right it ends up at the top left. I tried calibrating it but it keeps saying I failed. Any solutions?
    Nov 2006
    In another thread I think someone said to make sure that you hold your finger in place during calibration. Not 100% sure though...
    Jul 2007
    Use the Stylus
    on my screen, calibration also continuously failed when i used my finger. what you want to do is take the stylus and hold it in the dead center of the flashing x until it becomes solid green. Then move on to the next X until you are calibrated. If that fails, try searching for updated drivers. And if that fails, i'd say you have a bad screen and/or usb not getting enough power.
    Jul 2007
    had the same problem, I unistalled the drivers, deleted the folders and installed it again..it still kept doing it so I click on advanced on the calibration. software..and there is a grid like calibration....click around you will find it..it fixed mine
    Feb 2007
    Inverse Touchscreen on Lilliput EBY701
    Hi guys,
    Tried searching around but to no avail and that's why I have to ask the following question.
    I have just got a lilliput EBY 701 and the VGA is screen is working well on 800 x 600. However, as I am currently using Window Vista Home Basic, the package did not come with any driver for Vista for the touchkit. I did a search from MP3car and downloaded it from http://www.eeti.com.tw/web20/eg/drivers.htm (the Vista version).
    Upon installation, I realised that the cursor will move to opposite end (both vertically and horizontally). I tried to find touchkit in the Program folder but it is not there and therefore I could not carry out any callibration.
    I would like to seek advice from the forumers here on the approach to resolve the above issue. Thanks in advance.
    Rgds
    Mike
    Jul 2007
    Touch kit may have not made a proper link entry. When you click start in the search box type touch and see if anything come up. If not, I'll install it on my vista computer and let you know where it goes.
    Feb 2007
    Smile
    Quote Originally Posted by antidelldude View Post
    Thanks. I have managed to solve the problem.
    Dec 2008
    I am having this problem too. the cursor is inverted. i was wondering where do you find the configuration screen where you can calibrate the touchscreen? thanks.
    EDIT: I have found the drivers that i have been searching for quite awhile for. never mind.
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 10:36 AM
  2. Lilliput Touchscreen control not recognised
    By Brycestro in forum LCD/Display
    Last Post: 09-18-2007, 09:27 AM
  3. For Sale: Touchscreen from Lilliput 8" XGA display
    By Little-Acorn in forum Classified Archive
    Last Post: 12-30-2004, 11:19 PM
  4. WTB: Help me I need Touchscreen for Lilliput!!!
    By antofa007 in forum Classified Archive
    Last Post: 07-09-2004, 01:32 PM
  5. How I fixed my lilliput touchscreen problems
    By gubon13 in forum Input Devices
    Last Post: 05-22-2004, 07:21 AM
