Results 1 to 4 of 4
Thread: 5" tft with RGB inputs
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    5' tft with RGB inputs
    Hi,
    Yesterday I got this screen on http://www.amtex.com.au/display_pdf/P15.pdf from a friend of mine.
    It's a 300nit with RGB Inputs..
    Does this mean I can connect any vid.card with RGB outputs ?
    Or does the sync has some limits ?
    TIA
    Greetz,
    EDIT##########
    Since the controller card has 5 bnc inputs, could I use something like this ?
    it's from this page http://www.hut.fi/Misc/Electronics/c.../vga2rgbs.html which describes how to convert vga to rgb
    Greetz
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Jun 2002
    You've got two basic types of RGB interfaces. The first, RGB, uses 3 wires- Red, Green, Blue. It combines the horizontal and vertical sync on the green wire. If the controller is this type, then you would have to get a sync combiner to put convert the VGA signal to RGB. These can cost some serious cash.
    RGBHV, or the higher quality of the two, uses 5 wires. It has the standard Red, Green, and Blue, but also uses a (usually) white and yellow cable for sending isolated horizontal and vertical signals. If your controller has 5 inputs, then I would assume it is RGBHV, but I can't be sure without seeing it and looking through documentation. If it is, then you can use that schmatic or a cheap adapter cable.
    It's about $20. It's very well fabricated and provides noise suppression. I've used them before and they're well worth the investment. Probably too much information... Oh well.
    Jan 2001
    The Netherlands
    Hi,
    Thanks for the input,
    I suppose it's RGBHV, because it has these 5 bnc inputs, Red, Green, Blue, Horizontal and vertical Sync. So I think I go that way
    I just wanted to know if there are some limitations the display can't handle.
    But I get myself a good cable, and call it a day..
    Greetz.
    Raas
    Aug 2002
    a quick tip about those BNC cables... be careful with the bnc connectors and the single wires... they dont have any sort of strain relief.
    (Ive gone thru plenty)
