MAJOR datalux problem--HELP!!!
so i'm going along with my install listening to my mp3's as i work and all of a sudden the datalux screen starts to flicker. i checked the power connection and it was ok. now on boot up i dont get the first energy star screen but the next screen with the irq's and then the startup screen but then that goes completely out. i get the startup sound but no screen. i plugged my other screen that i am going to use in the rear(vga also) and it works fine.
anybody?
Depending on what model of Datalux you have, you may be able to press the two end buttons for the screen location adjustments at the same time and it will reset the screen to factory default settings, if it somehow got messed up. You need to press and hold them in. If you don't have those, just try opening the Datalux housing and making isure everything is snug.
hey thanks man!!! that did the trick.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
