Results 1 to 8 of 8
Thread: touch screen cal off, any suggestions?
    Newbie Wagonmaster's Avatar
    Mar 2007
    Camas, Washington (near Portland Oregon)
    I finally got my TM-868 to cal without locking my PC up but, when I touch the screen it is off by about 1/2" from where I touched it.
    I'm using touchkit and have tried 4, 9 and 25 point cals.
    Russ
    '93 Caprice Classic "Woody"
    SP13000
    TM-868
    Roadrider
    XM PCR, Usb Radio, WIFI, GPS, PCTV HD and 3G via tether
    Jul 2007
    Which version of touchkit do you have? Download the latest ones from here:
    http://www.cartft.com/support/drivers/TFT/
    Elsewhere
    Quote Originally Posted by kostyanj View Post
    Or here: http://www.eeti.com.tw/web20/eg/drivers.htm
    How about the Wiki?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    make sure your windows look right on the screen. meaning everything fit. if its not it will be off. Also make sure if you did fabricated the screen that its not bending it. That will make it go off too
    Mar 2007
    Quote Originally Posted by tn6478 View Post
    As a matter of fact, I am also having a problem with the window size, there is a "no man's land" at the bottom of the screen that the pointer dissappears into. I feel like it's a driver problem but I'm using the latest one.
    HMMMM
    Russ
    SP13000
    TM-868
    Roadrider
    Jul 2007
    Did you install the touchkit drivers from the link I posted?
    Mar 2007
    I'm already running touchkit 4.3.8.4207
    I think the problem may be with the driver for my chipset. I'm running a Via EPIA M10000 micro-ITX
    Russ
    SP13000
    TM-868
    Roadrider
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    Mine isn't very accurate either.. I calibrated by trying to offset the inaccuracy and using edge compensation. Also.. just in case you aren't, use a stylus.
  1. Review: TView 8" LCD Widescreen Touch Screen 56k Beware
    By AcuraTLFan in forum The Review Palace
    Last Post: 01-30-2008, 02:01 PM
  2. Replies: 4
    Last Post: 09-03-2006, 02:41 PM
  3. Lilliput 8" touch screen backwards - FC4
    By DJBigShow in forum Linux
    Last Post: 08-04-2006, 02:43 PM
  4. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 04:20 PM
  5. Need touch screen advice
    By sciff5 in forum LCD/Display
    Last Post: 05-29-2005, 09:58 PM
