Results 1 to 10 of 12
Thread: Jetway 7F2WE2G-OC-PB Dual monitor? (1) VGA (1) RCA ?
    Jun 2007
    Guam
    I have searched this forum and haven't found an answer, I am trying to get my rear RCA Headrest monitors to work with my Liliput 701 in the dash, but when ever I go to display properties it doens't let me set them up.....any help with this would be greatly appreciasted...oh btw it is running UniChrome....
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    check the bios and make sure u have crt and composite or crt and svideo enable
    Jun 2007
    Guam
    Could it be labeled as something else, I have check the bios and kinda got confused. Didn't see anything that was labled as composite or s-video. Thanks for the reply.
    Jun 2007
    Guam
    okay they are enabled...they save correctly, but when I boot windows and try to extend my desktop.....nothing, I check bios and the default has returned to CRT, when It was CRT&TV when I last saved....pls help super frustrated right now........thanks.
    Jun 2006
    Houston, TX
    not crt& TV crt & svideo its your bios. U might want to update it with a newer version
    Jun 2007
    Guam
    Quote Originally Posted by tn6478 View Post
    I don't have s-video inputs on my rear monitors, and where could I find an update.
    update: the jumper on the motherboard was closed, I changed the settings and video on rear monitors boots at startup displaying windows logo, but when windows actually runs, I lose the display. Thanks again for the help tn6478 if you can remedy this...we definately have to get you a case of your favorite brew !!!
    Jun 2006
    Houston, TX
    u dont need a svideo input just get an adapter or just use crt & comp. bios update can be found at jetway. and in display setting, set it to use the second monitor as and extended monitor.
    Jun 2007
    Guam
    Will do, we'll see what happens.
    Jun 2007
    Guam
    update, the bios I have is the latest from Jetway 06/07 any other suggestions, same problem...
    Constant Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    hey did you ever solve your problem i have the same motherboard with headrest tvs
    only the s video works how can i get the composite(rca) to work
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. VGA vs RCA, which to use
    By sxt173 in forum LCD/Display
    Last Post: 03-28-2005, 02:11 PM
  3. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  4. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 07:07 PM
  5. Different display using vga and rca out, how?
    By crispvx in forum General Hardware Discussion
    Last Post: 04-30-2004, 11:32 PM
