Hmmm......I took apart the dash today (twice actually), and made sure all
connectors (VGA, which is a barrel-screw-over type connector, the harness-to-lilliput connector, and the subaru harness adapter)were tight, and all inline fuses were tight and functioning. Everything is soldered and taped where ever wires were cut. Wiggling connections had no effect on the problem.
And again, it worked for a while, then started twitching, then went black, white, then black again, and just went to a white screen with no internal OSD that faded to black after that, every time I would
power it off and back on (though sometimes there were ghosts of chinese characters visible on the screen for a split second). It didn't matter if I had anything plugged into the
head unit at all besides power and ground...it did the same thing.
I emailed the person I bought it from off of eBay last night describing the problem, and they have 99.9% positive feedback, so hopefully they'll work with me to get this thing unbricked once I hear back from them.
Thanks,
-Rich
