Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Help about Lilliput EBY701
    May 2007
    Hi all !
    I'm italian and I'm going to purchase a lilliput EBY701.
    http://www.made-in-china.com/image/2...01-NP-C-T-.jpg
    I read this is a new model from lilliput, and I need it because it has a lower height compared to the others.
    My questions is, is this a good LCD as the other lilliputs ? And why this has a lower price in comparison to the others ?
    Please help me because I'm going to buy it in USA (I'm italian)
    THANKS TO ALL !!
    bye
    Mar 2007
    the 629 and 619 are a lot better.
    because the brightness is a bit better than the 701. As well as the fact that the 629 and 619 have the function/code ability to use the "auto on" feature by way of simple programming.
    I guess that's why they cost more than the 701.
    I believe the touchscreen is still the same quality.
    Mar 2007
    actually, the auto on programming works on the 701 as well. I'm not sure about the brightness diff, never seen the models side by side, so you'll have to take Snort's word on it. .
    May 2007
    Quote Originally Posted by Snortonnorton View Post
    I checked on the net, and I found they have the same characteristics:
    Contract 200:1
    Brightness: 400
    Responsive Time: 30Ms
    BUT IS HAS A MUCH LOWER PRICE ... why !?!
    May 2007
    I have the 701 and I must say there is nothing wrong with it at all. I have it set to auto on and it works, the brightness is fine. I can see it fine during the day. I think its a good buy! Go for it, you wont be disappointed.
    May 2007
    Quote Originally Posted by clutz2516 View Post
    thanks for the reply !!
    The last thing: does the 701 have the same (visible) LCD dimension of the others 7'' Lcds ?
    thanks !!
    Mar 2005
    I picked an EBY 701 for a friend's carputer...I must say for the price it isn't bad. However, the only annoyance I have is that when there isn't a signal, a blue screen is shown...so on bootup, it flashes blue a couple of times.
    Feb 2007
    Ottawa, Canada
    I've got the EBY701, and it's a pretty nice screen. No clue about the price. It has good features, and doesn't need auto-on, because it practically turns itself off if there's no signal.
    I've had it flake out at me because I think the case was on too tight. It would just display a white screen. I lostened the screws and it started working again, so no clue.
    The one really big complaint about it is the VGA cable sticks out beyond the dimensions of the screen. It's wider than DIN size because of the cable.
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Quote Originally Posted by Jamil20 View Post
    I've seen other quotes where folks said it was perfect or very near perfect double DIN sized, and fit very well into a double DIN sized space.
    Are you saying the cable would prevent that? Maybe if you have room to the side to accommodate the cable it wouldn't matter.
    Thanks, Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    Mar 2007
    wait a minute, I'm confused.
    If the 701 has the same auto power on features as the 619 and 629, then how come the fact-forum thread about auto-power on for liliputs only mentions the 619 and 629.
    also, why is the price so much more for those two than the 701 if the brightness is the same? it's like 230 dollars for the 619 and 629 but way under 200 for the 701. SOMETHING is different. whether it's the 4 wire touchscreen, the brightness, or contrast.
    just curious, because there has to be something different about them besides the case, the case is just cheap plastic and doesn't cost the factory anything different.
    one of you mentions that the 701 doesn't need auto power on because it turns itself off with no signal, but you didn't mention how you turn it ON. do you have to hit the button? that's what I want to avoid....
  1. Replies: 10
    Last Post: 05-20-2010, 12:14 AM
  2. Help Please, no display on Lilliput EBY701
    By notuptodateguy in forum LCD/Display
    Last Post: 12-27-2007, 12:08 AM
  3. Lilliput EBY701 Problems
    By DarkStar02 in forum General Hardware Discussion
    Last Post: 04-17-2007, 08:50 AM
  4. WTB: 7" replacement touchscreen Lilliput EBY701
    By jaw4322 in forum Classified Archive
    Last Post: 02-14-2007, 12:38 PM
  5. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
