sorry ignore my reply if you read it before the edit...i just reread what the question was....my bad!
I have a double-din opening. A single din head unit is in the top space and the lower space just has a pocket in it.
What's the largest lcd text display that I can use in a single din opening?
Thanks.
you might be able to find a 4x40 if you find one small enough.. the 4x20 i have the pcb is slightly too large to fit in a slot. a 2x40 would probably fit, if not any of that.. you are gonna have to settle with a 2x24 or a 2x20
the lcd places usually have a datasheet that will give you size specifications.
I know at least crystalfontz.com does
aka Kumaneko
"Don't make me moderate your ***!"
Maxima of Doom - project thread - photo gallery
mp3car system is currently FUBAR and finances do not allow for a correction of that situation
Real computer hackers use a rotary cutting tool on their motherboard.
a 4x40 will fit if you have a little leeway around the edges. My install:
Car: 1999 Dark Green Mustang GT Coupe
Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
Player: Empeg for now; something custom later.
www.neotechpc.com - Custom built laptops!
I squeezed a 40x2 with buttons in..
[SIZE=1]'91 Nissan Stanza
[XXXXXXXXXXXXXXXXXXXX] XX% Completed -
Car Totaled and i bought a 20G mp3 player
http://machs-fuel.tk
a DIY video projector page
Thanks for the info and pictures. A display would really complete the setup. I may be able to get a 40x2 in my dash with little modification. A 40x4 would be nice, but I'll go with whatever fits the easiest.
Any suggestions as to brands? Alot of the eio.com ones seem to be sold out. Is CrystalFontz the best choice?
do you want serial or parrallel? I would strongly suggest the 4x40. It is great for spectrum analyzers...
smashr2k,
I'm running MPXPLAY 1.47. So I believe it's parallel. I'll have to recheck. I'm not sure if MPXPLAY updated to serial or not.
And don't get me wrong, after seeing that 40x4 in your dash, it gave me a glimmer of hope. Do you remember any dimensions of the lcd module?
Also, what frontend are you using for the display?
Thanks.
i am using winlcd
attached is the pdf file for my lcd which has the complete dimensions. This lcd is availble for $20 for eio.com last time i checked
Thanks!! Do you have yours wired parallel?
