Results 1 to 9 of 9
Thread: Lilliput 629GL-70NP - No Input Signal
    Nov 2006
    I have just gotten to install this device after too many months working on my system.
    For testing, I'm using the 110v adapter than came with the device.
    I have the cable from the device plugged into the VGA port on a laptop.
    I have the USB cable plugged into a USB port and the latest(?) TouchKit drivers installed for XP.
    When I give the device power, the Red power light comes on as do the blue lights. They then go off.
    I also see PC on the upper right of the display for a short while.
    I then get a red bordered box with the message "No Input Signal" that shortly disappears leaving a black screen.
    Only the power and tv/av buttons on the remote and the device get a response. Menu gets nothing.
    Win/XP doesn't know about the device i.e., it is not in the display settings.
    I'm beginning to belive it is a bad cable. If so how can I test it? Any specs on the pins?
    If the cable is bad, where do I get one?
    Regards,
    Jim
    Nov 2006
    Never mind. The warranty on my brain ran out when I turned 65.
    All works just as it is supposed to.
    Regards,
    Jim
    Sep 2007
    How did you fix it again...
    I really got to get this thing working. What exactly did you do ? I have the same symptoms
    Nov 2006
    Antman56,
    On my laptop I have a function key that switches from the laptop display to an attached display.
    When I pressed it the laptop display also showed on the 629. When I pressed it again the image only showed on the 629.
    I then went into the Control Panel->display and set the resoluton for that display to 800x600.
    At least I think that is what I did. As I said the waranty on my brain ran out when I turned 65.
    It was actually a sequence I should have remembered as it was exactly the way I got a 21" auxillary display to work on another laptop.
    Regards,
    Jim
    Feb 2007
    anyone found a solution for this matter yet?? thanks!
    May 2006
    I just got a lilliput 629 and it has the same exact problem. I think it's a problem with the connector itself because I jiggled it around a bit and the vga signal showed but then it went back to the no input screen. Does anyone know where you can get a replacement connector?
    Car: 2007 Honda Accord Sedan SE
    My Worklog
    http://www.mp3car.com/vbulletin/work...da-accord.html
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Just got the lilliput 629 also, same thing menu button has no response. remote control doesn't seem to work either.
    Anyone know how to access menu?
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Mar 2004
    Greenacres, WA
    Ok, menu button works only when you have an active input signal.
    Sep 2007
    i have the same problem it seems to be the trapezoid connector on the from the screen to the cable. i wish it was a screw in type rather than a push on one. i can wiggle it and it goes back on but sometimes when i hit a bum or something it will go out again and i have to wiggle it. i tried taping the thing in there and using velcro but nothing seems to work anyone else got any ideas on how to make it work better?
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 09:36 AM
  2. FS: Lilliput 7" Touch Screen XGA TFT Car Monitor 629GL
    By jwong3854 in forum Classified Archive
    Last Post: 11-15-2006, 03:07 PM
  3. Replies: 3
    Last Post: 01-28-2005, 03:32 PM
  4. Lilliput composite input flashing?
    By Misanthro in forum LCD/Display
    Last Post: 12-09-2003, 03:58 PM
  5. Input signal for 6" Sharp LCD screens
    By Fosgate in forum General Hardware Discussion
    Last Post: 05-03-2000, 11:23 PM
