I think the life should be pretty good, and out of everything, id only worry about shutting off the back light.
Just solder a little switch into the line thats feeding power to the back light.
What's the average lifespan of a 40x4 character LCD? I'm wondering if it would be better to turn it off if I'm listening to the radio. How could I rig an on/off switch to the LCD without damaging my power supply, as I use a molex to get the +5 from my power supply (AC/DC)? I want to turn off the actual screen, not the backlight or the contrast all the way down.
Silver 1999 Nissan Pathfinder!
Completion: [*********-] 90%
Everything working! Mobile MP3s ROCK!
LEFT TO DO: Improve power on circuit, fix slow boot time
- 550mhz PIII on Abit BH6
- 128MB RAM
- 40x4 Backlit Character LCD
- 17 key numeric keypad - Repainted buttons
- 2.1GB laptop drive for OS
- 4.3GB drive for MP3s
http://www.mp3car.com/usersites/bombboyer/ Redesigned, new pics!
I don't think that will work, as I think it will blow a PS if you plug/unplug things with the computer on. Any other ideas?Originally posted by Charliey
- 128MB RAM
You shouldn't have to wory about the lifespan of your lcd, as most of their mtbf are quite long (think lcd clocks in early 80's cars).
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
If youre only turning on/off back light, it should be alright.
The problem occurs is when you accidently short the power supply wires when your computer is running. Then it restarts.
The other problem that can happen is its not good for the LCD processor when there is a signal applied to the data pins (ie it is plugged into the parallel port), but it does not have power supplied to the power supply pins.
So, only install a switch to turn off the back light, not the main power to the screen, unless you remove the parallel connection with it.
