Results 1 to 8 of 8
Thread: Are there any USB/RS232 programmable LED signs for me?
    Apr 2003
    Norway
    I have an 17" LCD monitor in the rear window, so I can send insults to cars behind me and do some other fun stuff (road rage isn't really that common in Norway, don't think I would do this in Alabama...). But this really only works when it's reasonably dark outside (at least dusk - no point at all in sunlight). Is there a reasonably priced LED sign I can use instead, one that can be read in sunlight? It would need some kind of interface so I could send the messages in realtime, the easiest would probably be some form of RS232 protocol since Girder has a serial driver that probably will be able to send the commands. So any suggestions would be appreciated!
    Tor - The MediaSUV
    Mar 2006
    Colorado, but Canadian!
    You could probably use something like this: http://www.geeks.com/details.asp?inv...-BADGE&cat=GDT
    You can program it over USB. I dont know too many details of it though.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Westminster, MD
    OH man I ahve been dying to do something like this, "Back the **** off!!" for tail gaters, would be my favorit!!!
    check out these
    http://www.asayo.com/list/led-signs.htm
    '95 Mitsubishi Eclipse GSX
    CarPuter [Under Development]
    Apr 2003
    Norway
    2K1Toaster, unfortunately not. That one isn't built for real time programming, only for preprogramming and then running. It has a proprietary programming system that I wouldn't be able to access.
    EQNish, those could be used, yes. Thanks! Just gotta save up a bit first, they're quite expensive...
    Tor - The MediaSUV
    Mar 2006
    Ah, I figured if you hardwared it to a power source and left the usb cable connected, you could interface with it that way. Program the device each time you send a message, not just stream the data. But if you cant access it then i guess that wont work!
    I'll keep my eyes peeled for you. Although most I have seen are the really big ones, and those are expensive!
    Apr 2003
    Norway
    Yeah, I know. And many of them are made for indoors use, so they're not powerful enough. I did find one on eBay that looked promising, but I don't think it'll shine through the tinted rear windows.
    And thanks, please post to this thread if you find anything, so I get an E-mail about it.
    Tor - The MediaSUV
    Low Bitrate EagleTG's Avatar
    Mar 2002
    Pennsylvania
    Keep an eye on eBay. I know a guy who runs tournaments, and was able to find real-time programmable LED scrolling signs on eBay for SUPER cheap. They were RS232. He built a VB app that controls them using the documentation from the manufacturer. I think the signs had some sort of DOS app that you pumped data to, and they would send it to the screen. His VB program controlled this DOS app.
    -Eagle
    Hardware and Software [#####] DONE!
    Fabrication [#####] DONE!
    Installation [#####] 99.314% (I like Pi! The project is never done.)
    --=> My CarPC Project & Link to Worklog :: My Blog/Website/Photo Gallery <=--
  1. Red LED compass and/or thermo
    By WxGuy1 in forum Hardware Development
    Last Post: 08-06-2005, 01:26 PM
