Hi guys !
Now at long last I have my Lilliput EBY701. But I'm not able to set in WinXP the 800x480 resolution. I checked all the settings, there is 800x600, 848x480, 960x600 but not the lilliput's native resolution.
I tried Powerstrip, but nothing happened.
WHAT CAN I DO ?
In the other resolutions the output is very bad.
Please help me
THANKS,
bye
Well, firstly I tried my GeForce 6800 on my desktop pc. It doesn't have 800x480.
But now I tried also the carpc's video card: an integrated Intel 82815, with 32Mb. And also there, there is not lilliput native resolution.
Please help me, otherwise I spent a lot of money for nothing![]()
I also have the 701 and it displays 800x600 perfectly fine. using i845g embedded graphics. can't set 800x600. I haven't tried Powerstrip, but I think you can run custom resolutions with it.
I don't understand you at all. Now you use 800x600 or 800x480 ? If you also tried 800x480, can you conferm me that 800x600 is not, compared to 800x480, too bad ?
Powerstrip allow you to select the same resolutions windows allow to choose. Nothing more than them.
I use 800x600. It looks good.
Within powerstrip, you should be able to create a custom monitor driver, and specify resolutions within that driver. You should also be able to create a custom resolution and have Powerstrip switch to it on bootup. This was/is used quite a bit with HTPC setups which have video cards which don't display the desired resolution, or there is unwanted clipping in the standard TV resolutions.
:edit: try this link for a go at powerstrip - http://www.xenarc.com/faq.html#QA1
here's a thread on the subject of 800x480 Intel 865 custom drivers
