Results 1 to 4 of 4
Thread: Xenarc overlay "loose"?
    Jul 2007
    I was running some tests on my Xenarc 700TSV, when I noticed the screen was loose.
    I'm assuming the touchscreen is some sort of overlay that goes over the actual LCD, so to be more specific the overlay isn't very secure and shifts if I move it with my finger side to side or up and down, doing so reveals a checkered pattern at the edges.
    Is this normal? Or does something need to be tightened or fixed?
    I'll post some pics tomorrow.
    Aug 2007
    Quote Originally Posted by Jun_el View Post
    I have talked with my sales guy there and he tells me they had a few in mfg that did that. The front glass plate is not secured to the LCD itself, and if not secured properly will slide around. You can actually see the problem very clear if you open it up. I'm sure if you email them they will RMA it for you (before you open it!). Mine came brand new last week and had the same problem.
    Jul 2007
    Quote Originally Posted by changeip View Post
    Thanks for the response, that sounds exactly like what I'm describing, I'll call them ASAP. Thanks!
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    If I remember right, the LCD overlay was just held on by two sided sticky tape to the outer housing. I can't remember right.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    VIA EPIA M10000 Mini-ITX Motherboard
    Iguidance GPS
    Road Runner Frontend w/ DFX5.0.3
    Xenarc 700IDT with DVD CDR/RW
  1. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  2. Xenarc 700YV with Touchscreen Overlay
    By Zynester in forum LCD/Display
    Last Post: 08-16-2007, 11:02 PM
  3. xenarc monitor and TS overlay
    By MrJayDeeOne in forum LCD/Display
    Last Post: 01-02-2007, 06:42 PM
  4. Replies: 2
    Last Post: 05-04-2005, 09:55 AM
  5. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
