Results 1 to 6 of 6
Thread: Xenarc 700TSV Problem (Gradiant White Screen)
    Jul 2007
    Cleveland, OH
    Unhappy Xenarc 700TSV Problem (Gradiant White Screen)
    I just got a 700TSV off of ebay and made an ATX barrel connector for it. I plug it in (power) without plugging in the VGA cable (I do not have on yet, ordered it from Xenarc) and I first get a black screen, and then gradually the upper left corner of the screen fills in white pixel by pixel. Then, after about 5 seconds, the screen goes black and the green light blinks on and off.
    Pressing any of the buttons on the bottom of the monitor resets it and it goes black, and then the corner gradually gets white again.
    It looks like this when the white apears:
    Do I have to have the VGA cable in there to have the screen load properly? Can't I access the Xenarc menu w/o the cable present?
    Anyone have any thoughts? Is it dead? Should I wait for the VGA cable (due in on Wed)?
    May 2006
    Calgary, Alberta
    I think you got jacked.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Constant Bitrate Homebrew's Avatar
    Maryland
    Make sure you wired it correctly, because I've plugged mine in many times without having the vga hooked up and have never experienced that. Though I do have an older xenarc, this still doesn't seem right. I've seen something similar on a lilliput that occurred because something inside was hooked up backwards. I think it was the backlight inverter, but I can't say for a fact since I'm not very familiar with liliputs. So if you have taken the screen apart, or have reason to believe it has been taken apart before, you may want to check the connections inside. Also, check to make sure you wired the ATX connector correctly.
    -Kevin
    Jul 2007
    Cleveland, OH
    I am pretty sure it is wired correctly:
    This is the message I got from the seller:
    That usually happens when you turn it on. Make sure the power supply is tight in the back of the monitor, and did you try hitting the far right button to change the video? Let me know if that works
    Can anyone confirm that? Like I said before, pressing the right most button (M), seems to simply cycle it.
    I haven not yet opened the case up and don't plan to untill I get some more info b/c the Xenarc warrently sticker is still covering one of the screws and I dont really want to break it.
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    11.69 volts without a load? When you plug that into your monitor it will cause a voltage drop from the load of the monitor. So you may only me putting 9.5 to 10 volts to the monitor. Try to get a better source of power. Also if the monitor doesn't have an input signal after 5 seconds the monitor will go into stand-by, hence the blinking light. This is normal.
    Just noticed you said your running off an ATX power supply. It will still cause a voltage drop, also most all ATX are cheaply made, and are noisy as hell. Get a clean 12v source, I bet your problems will disappear!
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    VIA EPIA M10000 Mini-ITX Motherboard
    Iguidance GPS
    Road Runner Frontend w/ DFX5.0.3
    Xenarc 700IDT with DVD CDR/RW
    Jul 2007
    Cleveland, OH
    The ATX is for testing only. The system will be running off of an M2-ATX when it goes into the car. I am waiting for the VGA cable to come in from Xenarc. I will update then. Thank you all very much for your help thus far.
  1. Replies: 3
    Last Post: 05-19-2006, 05:10 PM
  2. Xenarc white-screen problem after bezel swap
    By dune in forum LCD/Display
    Last Post: 05-10-2006, 08:43 PM
  3. xenarc 700y-yv problem
    By jurgen in forum LCD/Display
    Last Post: 08-19-2005, 10:34 AM
  4. Replies: 1
    Last Post: 05-01-2005, 01:25 AM
  5. My White Screen of Death
    By phatchink in forum LCD/Display
    Last Post: 03-02-2005, 05:13 AM
