Results 1 to 5 of 5
Thread: Xenarc Powe Through M2-ATX Problems
    Jun 2007
    Oxnard, CA
    Hey guys/girls,
    If anyone could point me in the right direction that would be greatly appreciated. I have an M2-ATX powering an M10000. I am trying to power a Xenarc 700Y screen off of the 12V rail but I think I have a power problem somewhere.
    The computer locks up during POST when I have the screen plugged into the rail but if I use a separate power plug for the screen (such as the wall outlet) I have no problems.
    I have connected a meter to the outputs on the rail and the voltage stays at 11.95VDC and occasionally drops to 11.94VDC.
    Other than motherboard fans this is the only device on the 12V rail.
    Any ideas?
    Elsewhere
    Why power it off the PC's PSU?
    IF you power it with an igniion-controlled power source, the Xenarc will turn on/off with the ignition. You can do this because Xenarc screens have a built-in 12 volt regulator.
    How about the Wiki?
    Jun 2007
    Oxnard, CA
    ...wow I didn't know that. I had heard they needed a regulated power source.
    Thanks a lot!
    Jun 2007
    Oxnard, CA
    Would the Xenarc happen to include its open fuse as well?
    Elsewhere
    How about the Wiki?
  1. Xenarc MP users with ATX connection!!! Solution...?
    By looneeii in forum Power Supplies
    Last Post: 03-05-2005, 05:56 PM
  2. Xenarc 10.4" touchscreen problems
    By basscoholic24 in forum LCD/Display
    Last Post: 02-25-2005, 10:47 PM
  3. Xenarc Problems
    By peteruk in forum LCD/Display
    Last Post: 09-04-2003, 02:26 PM
  4. Having problems with a Xenarc touch
    By Falken in forum Input Devices
    Last Post: 04-28-2003, 09:09 AM
  5. atx supply problems
    By oddcomp in forum Power Supplies
    Last Post: 10-21-2002, 11:05 PM
