Results 1 to 8 of 8
Thread: Any results from using a VGA duplicator/booster?
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    As soon as I added the VGA extension cable to my carpc the quality on the screen took a nose dive. I've gotten used to it, but I know it can be better.
    There is an ATEN VS92A VGA signal booster for $30 on eBay (Buy It Now). I am wondering if this would be sufficient to reduce the signal loss I get?
    They also have Belkin OmniView extenders for around $20. Seems like a cheap deal. There are a few that carry over cat5 as well (two units).
    Low Bitrate marshallh's Avatar
    Apr 2005
    Kansas
    That happens when you get crappy VGA cables. Basically, you get what you pay for. You're probably better off getting a high-dollar cable from a place like a network or audio supply place.
    Progress:
    [■■■■■■■■] 100%
    Mitsubishi 3000GT car computer
    Previous budget Honda carputer
    Feb 2005
    Yeah I got pretty cheap cables. What's the going rate for good VGA cables?
    Sep 2006
    i bought mine from a local computer store i work at... look for ones with good shielding, the only problem is that there so thick they are hard to bend and hide.
    here is a website that seems to have the same one I have
    http://www.vga-cables.net/premium-vga-cables-list.html
    Mar 2007
    before you buy more ****,
    are you sure that maybe just one of your vga cables is cheap and not shielded enough?
    maybe try a different VGA extension.
    I extended mine and don't have any noticeable drop.
    Mar 2007
    wha'ts funny is that the high quality vga extension was cheap at cirquit city, but the usb extensions are expensive as fuc*
    Apr 2005
    Kansas
    You should pay upwards of $20-30 for a good 6' VGA cable. Likely your problems will disappear when you do that.
    Why are USB cables so expensive?? Because printers sell dirt cheap, and do not include a USB cable.... So you buy their $30 cable seperately so they makeup the loss on their printer.
    Progress:
    [■■■■■■■■] 100%
    Feb 2005
    Quote Originally Posted by Snortonnorton View Post
    That's actually the problem I think. I bought a cheap eBay cable for around $20 (25ft). It's fairly thick, much thicker than the one that came with the screen. It works great for a CRT monitor, but when it comes to VGA on an LCD, quality deteriorates right away.
    I also have extra slack, much more than I needed. I'll try getting a shorter cable of higher quality.
  1. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 08:02 AM
  2. Laptop to Factory Nav Screen - VGA Detection Pin
    By tejesh83 in forum LCD/Display
    Last Post: 06-14-2006, 12:54 PM
  3. VGA upgrade for TM-701L
    By digitalww in forum LCD/Display
    Last Post: 08-01-2003, 09:01 AM
  4. Xenarc VGA or Composite
    By GTPmp3PC in forum LCD/Display
    Last Post: 01-14-2003, 10:15 AM
