Results 1 to 4 of 4
Thread: Screen Setup
    Oct 2005
    Screen Setup
    OK I have been searching this site for some time to find an answer. I found a couple things that I would thought help but have not. I have the non motorized screen in my 2003 eclipse. I have power from the screen going directly to the battery with a fuse and relay switch connected to the power line. I also have it grounded to the same spot as my car stereo. My screen seems to be flashing and moving a little and it is not always completely a clear picture. When I bring up the menu for the screen it doesn't do what the picture does(doesn't shake, move or anything) I have looked at my settings and found nothing that seems to make this better. Is there any ideas on what could be the problem? This is getting really annoying and I am not sure what to do about it
    Oct 2005
    anything? Could it be a bad vga cable? Interfearance with the vga cable? I am looking for any options
    Oct 2006
    sounds like a really bad source (are you using RCA?) OR it is a bad ground / +12v connection...
    if the menus are fine, but the source is bad, you need to double check all your connections...
    Oct 2005
    I have checked all my connections and they are good. I am using the same ground for my screen that I use for my stereo. That is why i am starting to think that it might be my VGA cable.
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  2. Full screen visualization Setup Error (CF 1.12)
    By ninja0n3 in forum CF Bug Reports
    Last Post: 05-02-2007, 12:43 PM
  3. Xenarc 700TSV 7'' touch screen
    By krazymarine in forum Classified Archive
    Last Post: 09-20-2006, 11:55 PM
  4. Wtd: 8.4" Touck screen setup
    By Glyn in forum Classified Archive
    Last Post: 09-06-2002, 05:18 AM
  5. can you use a laptop screen for a mp3car setup?
    By brandondere in forum General Hardware Discussion
    Last Post: 03-21-2001, 10:41 AM
