Results 1 to 5 of 5
Thread: Lilliput brightness issue
    Sep 2007
    Whenever I power on my CarPC, the Bios screen looks perfect, then the Windows XP booting screen looks the same, but once windows loads the normal desktop, the brightness is soooo high that it almost looks white. Its horrible. This is the wierd part, once RR boots up and the skin load, the screen quality and color is perfect again. If I use the web from within RR, itll open Internet explorer inside RR, but the color of IE is horribly bright again and almost impossible to read, yet the RR skin around it looks perfect. What do I do, its driving me NUTS!!!
    Low Bitrate marshallh's Avatar
    Apr 2005
    Kansas
    Go into your display properties. You might have gamma turned way up. Try a different refresh rate.
    Progress:
    [■■■■■■■■] 100%
    Mitsubishi 3000GT car computer
    Previous budget Honda carputer
    Sep 2007
    would that be on the lilliput display options or the pc?
    Apr 2005
    Kansas
    That would be on your computer -
    Start > Control Panel > Display > Settings > Advanced...
    It will be somewhere in there if your driver supports it.
    Progress:
    [■■■■■■■■] 100%
    Sep 2007
    i can get it to change the gamma, but after a bit, any carpc software i use changes it so the frontend looks perfect, but if i goto the desktop, its horrible. So i then manually adjust the gamma, and its still almost impossible to read. I am so lost right now..
  1. Help Please, no display on Lilliput EBY701
    By notuptodateguy in forum LCD/Display
    Last Post: 12-27-2007, 12:08 AM
  2. reversed polarity == Kentucky Fried Lilliput?
    By hud in forum LCD/Display
    Last Post: 11-09-2005, 08:39 AM
  3. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  4. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  5. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
