Results 1 to 9 of 9
Thread: Lilliput Touch Screen Issues
    Jul 2007
    Exclamation Lilliput Touch Screen Issues
    Ok well I have my screen powered and I went to test everything out before final install of everything. THe touchscreen is really off, I tried running the calibration a few times but when I touch the X in the bottom left hand side of the sceen, the mouse pointer goes to the top right. So I am noticing the arrow is always opposite I guess. I have the GL701-NP/C/T model. I just downloaded the new drivers and will try that out to see if it will fix the error. During installation did you check PS/2 driver to be installed? Wasn't for sure what that was. Should I not have selected that option? I've done some searching and no luck. Any help would be appreciated.
    Btw my pc is an HP Vetra E-PC, very old but usable.
    Mar 2006
    Colorado, but Canadian!
    If your touchscreen is USB, then no ont select PS2 connector. And the opposite thing is very common. Just calibrate it. When the X shows up, do the full 4 point clicks, then it will save the info and it will work.
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2007
    Ok thank you very much. Do I just tap the x repeatedly or touch & hold?
    Mar 2006
    Touch and hold. It should beep when registered through the speakers
    Jul 2007
    Ok, Second problem. When I touch the screen, the internal speaker (usually for errors) beeps continuously while I touch the screen on the desktop. Any reason why it would do that ( still havent tried out newer drivers)
    Mar 2004
    There's an option in the software to disable the beep when you touch the screen
    Jul 2007
    AHh thank you. I did find it eventually. Thanks to everyone for their help. Sorry for my noobness
    Nov 2010
    Similar problem
    Screen was working Calibration was good now screen is out of wack, when i go to calibrate The blinking x stops blinking by itself n wont move to another córner
    Nov 2010
    hi.... i got this problem !!!!
    This device cannot start. (Code 10)
    Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
    is my mouse i can't fix it and my touch screen is not working
    windows vista home
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  2. Can't calibrate lilliput touch screen
    By _wd in forum LCD/Display
    Last Post: 02-14-2007, 11:10 PM
  3. FS: Lilliput 619gl-70np/c/t 7" touch screen
    By kingeorge36 in forum Classified Archive
    Last Post: 05-06-2006, 04:52 PM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen
    By JonX69 in forum LCD/Display
    Last Post: 03-06-2004, 02:22 PM
