Results 1 to 5 of 5
Thread: Xenarc 700tsv won't turn on
    Jul 2007
    I tried to turn my screen on after I put it in a case I made and it turned on but then white would creep up the screen. I looked at the ribbon cable and it must have got damaged. I bought a new one but when I plug it in, the screen doesn't even turn on anymore. The green light on the front doesn't even turn off after a while. Anyone have any suggestions on how to help?
    Jul 2007
    anyone?
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Hmmm, check the voltage going into the monitor, make sure you have 12V.
    I took mine apart, beat it up pretty good...and it still works.
    The green light does not turn OFF? must be gettin voltage then.
    Sounds like you might have messed up a board...double check that ribbon cable.
    Wish I had a better answer...sorry.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Jul 2007
    Ok tried to find to test the voltage to the monitor but I'm not getting anything. What wires should I test. The board is getting power for sure and I think the monitor is too. I cant be sure the monitor is getting 12 volts. Another thing I've found is one of the resisters is getting really hot. It might actually be burning something too. I cant be sure though. Also I have noticed the the green light might be dimming over a period of time. Does this bring up anymore ideas?
    Oct 2007
    I have the same problems with my Xenarc and have come up with nothing. My ribbon cable is also damaged and I was thinking that was the problem. I took a multimeter to the board and it is getting 12V. If it makes a difference I never had this problem until I pressed a little too hard on the corner of the enclosure and shattered the touchscreen. I replaced the touchscreen and I get ALL the same problems as CloakingHalk. Any advice is much appreciated.
  1. FS: Xenarc 700TSV controller
    By ayclens in forum Classified Archive
    Last Post: 03-13-2006, 11:56 AM
  2. FS: Xenarc 700TSV $250obo
    By tejesh83 in forum Classified Archive
    Last Post: 02-12-2006, 09:24 PM
  3. Xenarc 700TSV and Gain 700TSV the same?
    By thrmaln in forum LCD/Display
    Last Post: 02-10-2006, 09:22 PM
  4. Xenarc 700TSV Buttons.....
    By Cheekz185 in forum LCD/Display
    Last Post: 07-11-2005, 12:20 PM
  5. Does XENARC 700TSV has remote?
    By EluSiOn in forum LCD/Display
    Last Post: 12-20-2004, 08:32 PM
