Results 1 to 6 of 6
Thread: need help
    Oct 2002
    Chandler, AZ
    need help
    i need to know what i will need besides a source obviously (and space) to hook up the lcd in the link below...any help is appreciated....
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1385814053
    Maximum Bitrate GuRuGoD's Avatar
    Jun 2002
    Omaha, Nebraska
    I may have missed something, but he/she never says what brand or model number the LCD is. This means that it is going to be hard to tell what else you will need. You will most likely have to purchase a controller (~$200-300) and possible an inverter. CHeck out the manufacturer and model then post again.
    90% Done
    60W DC-DC & shutdown controller
    Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
    Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
    All in a shiny White 2000 V6 Mustang
    Click here to visit my NEW PhotoAlbum
    Oct 2002
    Chandler, AZ
    so basically, i would be better off buying one with the controller and inverter? inverters seem to be cheap, and the only controller i found, was $329...but for $399 i can get a 12.1 with everything even a tv tuner and speakers...that seems like a better route. thank you for your help GuruGod.
    Jun 2002
    Omaha, Nebraska
    yeah, inverters arnt too expensive, but its the controllers that will bite you in the ***. The problem is that 5.6-10.4" screeens arnt made in the numbers they make 14.1 and 15.0" screens. Means more expensive. If you want to go that big, its prolly better to just buy a retial 14.1 for $200
    90% Done
    Oct 2002
    Chandler, AZ
    where can i get the 14.1 for $200? does that have everything i would need to hook up in my car? im going to run a computer i have sitting around and an indash dvd player....thanks again
    Jun 2002
    Omaha, Nebraska
    bestbuy has mag 14.1" lcd for 200 after rebate. it will be vga, dont know about power.
    90% Done
