Hi guys,
After months I finally had a free day to try to finish off my Install.
Spent most of the day carefully soldered my Dell SX260 cable to the DSX12VD then I connected this all up (with the battery disconnected) to the battery through a distrubution box.
I have also connected my touchscreen car adapter cable power cable to this box also (red-positive, white- ground).
Once I connected the battery up the PC powered on fine but the screen will not power on at all. This was tested a week ago and the screen worked fine, I've checked the connections and all seems ok.
Any ideas?? As the wire is very thin should I try another cable (are these available seperately?)
Any help is appreciated as I spent ages molding the screen into the dash and I'm preying its not a dead screen.
