Results 1 to 8 of 8
Thread: LMV10R Owners
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    LMV10R Owners
    What driver did you use to get your datalux up and running. I'm referring to those who downloaded the drivers from www.3mtouch.com . There are a few drivers but I have no idea what's going wrong here.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    anyone? Okay if you own a Datalux LMV10R (10.4" touchscreen)what drivers are you using... from anywhere?
    Maximum Bitrate allenruble's Avatar
    Jun 2001
    somewhere
    www.sounddomain.com/id/2000mp3ranger
    Mp3 player - 10.4 Allbrite Gigabyte GA-71XEH , 700 mgz t-bird , coolmaster fan , 2x 128 ram + 1 512ram , ATI-RAEON RV100 ,on bd sound , Linksys Wireless-B usb network adapter , 20G IBM TRAVELSTAR
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    that's the one I have... I guess that's not the problem. The touchware program tells me there is no controller found. But the serial cable is in the serial port... I'm not sure what to do from here.
    Sep 2001
    That could be a number of things. If you are certain the hardware and wiring is all properly set up...try this:
    1. Install these drivers.
    2. They will probably not work, so then, uninstall them and install these drivers:
    3. Now it should start working, if it does not then my guess is your wiring is hosed or you have your jumpers set incorrectly. I could probably verify this with pictures of your setup.
    Yes I know this seems asinine, but it's what I had to do to get mine to work properly. It was definitely a software issue.
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    you also may check which serial port you have it assigned?
    BossTone74
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I'll give it a shot Matty... and BTW... your idea with the Belkin VGA Amp DID get me my video. Thanks for that. If it doesn't work I'll get some pics for you.
    To bosstone:
    I've tried 'em both. Plugging it into each and then trying to assign it to each. We'lll see later this afternoon.
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    mine only works on com 1 and for the longest time coundn't find the touchscreen but worked anyway. dont know y. but now for some reason its fine
