Results 1 to 2 of 2
Thread: Xenarc 700IDT No Image, ribbon cable slightly cut! Help! *Pics*
    Aug 2007
    Hey guys!
    Well after about 3 months of good use, my Xenarc 700IDT (new 500nit brightness one) decides not to display an image anymore! first i thought it could have been a loose VGA connection somewhere down the line between the carPC in the back and the extension to the monitor, but i tested each point with a CRT monitor and the computer is putting out the correct display! it had me stumped for a while!
    See the thing is the Xenarc can see the display resolutions being sent to it, i.e. when i boot the PC it shows "PC" then shows "600x480" at POST and when i know the PC proceeds into boot into windows it shows "600x480 @ 61hz" so it had be kind of stumped as to why it was getting the correct resolutions yet not displaying the image..
    So, after all my testing i narrowed it down to the unit itself, i looked at the VGA connector, fine, then i thought the cable behind it might of come loose, but seeing as it was secured well i decided to check everything else.
    I looked behind the monitor to check the ribbon cable, and viola! i think i spotted the issue. what happened is the swivel (tilt side to side) action has a piece of metal that supports the monitor and due to poor design (on Xenarc's part) the ribbon cable sits right next to it, and when swiveled right it hits the cable!!
    Okay heres a few pics of what i mean! (sorry about the blurriness)
    Okay so what do you guys think? What are my options for repairing this? Seeing as i live in Australia, do you think my only option is to RMA it back to Xenarc?
    Adam
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I'd think you would be able to replace it yourself. Contact Xenarc and see if they'll send you the cable.
    Even if you have to buy the cable it would be cheaper than your shipping costs.
    But I'd get their approval to do it yourself...not to void any other warranty.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. FAQ: How to install a DVD R/RW in your Xenarc 700IDT
    By cdcamaro9534 in forum The FAQ Emporium
    Last Post: 12-10-2007, 01:34 PM
  2. Xenarc 700IDT Resolution Issues! HELP!
    By gotrice05 in forum LCD/Display
    Last Post: 08-29-2007, 09:54 AM
  3. Dont buy a Xenarc 700IDT!!!
    By cdcamaro9534 in forum LCD/Display
    Last Post: 04-12-2006, 05:29 PM
  4. LCD controller ribbon cable
    By UM_Fan in forum LCD/Display
    Last Post: 02-07-2006, 07:22 AM
  5. Lilliput 8" ribbon cables?
    By therussman2002 in forum General Hardware Discussion
    Last Post: 12-24-2004, 10:17 AM
