Hi there. I recently installed my Xenarc 700IDT. It worked perfectly fine on the bench with a regular computer
power supply, but it does not want to turn on when hooked up to the car. I have it drawing power from my M2-ATX, with the remote turn-on wire spliced into a 12V feed on my headunit. A test of the voltage at the monitor harness input shows voltages of between 11-12V for both the turn-on and power lines.
One thing I accidentally did was I touched the negative of the harness to an active +12V line from the car and I noticed some sparking. Did I short something? I checked the fuse on the positive line, but it seems to be fine.
Does the turn-on signal absolutely need 12V, or would something a little less (>11V) still work?
I would really appreciate some input.
