It could be fixed but you would have to open it to do that. Since its under warrenty I'd just send it back. I sent my 700IDT back twice when I bought it new before they got it fixed right.
As I stated in the title I just received a new xenarc 700tsv and it looks really good however, touch screen mechanism moves up, down, left and right for couple of mm. If I push it all the way up and calibrate it, then pull it down and check the calibration I find out that it is off by a distance equal to the movement it made. Now my question is does anyone else experience this or how normal is this? Also should I just send it back for a replacement. Thank you
1995 Chevy Camaro
2003 Dodge Ram 1500
VIA EPIA M10000 Mini-ITX Motherboard
Iguidance GPS
Road Runner Frontend w/ DFX5.0.3
Xenarc 700IDT with DVD CDR/RW
There are 4 screws internally that act on little metal strips to clamp the screen elements to the face frame. Sounds like they weren't tightened enough - or perhaps overtightened and stripped out - in either case if it's under warranty, it needs to go back.
Thanks guys, I will send it back then.
