OK so I have been noticing that every time I drive my car the usb portion of my 700tsv "goes out". I constantly hear the Usb plug in/ un plug notification noise, when u hear the noise the TS does not work, but when the noise repeats the TS starts to work. I checked the usb plug and everything is fine. I also check main connecting harness on the xenarc and it is connected nice and tight. Unfortunately the way my xenarc is molded I HAD to leave the back cover plate off.
I noticed the usb control module: CY-4W-USB-03. And If i jiggle with that the usb WORKS! I am wondering if i replace that board if it will work. But now on the CY-4W-USB-03there is a flat ribbon cable that im guessing goes to the TS controller panel and the other end of the CY4WUSCY-4W-USB-03B03 module there is a harness with 4 wires and it connects to the the main harness.
I came across this post
How I fixed my lilliput touchscreen problems.
But on the lilliput the usb controller has solder connections, on the Xenarc the usb controller connects to the main harness via a 4pin cable.
Any input would be greatly appreciated!
