Results 1 to 6 of 6
Thread: Monitor question help
    Jul 2007
    Ok Hello everyone,
    I am a little confused as to why lilliput and xenarc would not already have monitors that would connect to the cars power source. Why do we have to cut and splice a cigarette charger to get what i think should already be included. Please keep in mind i am a newbie and just stating my observation. OK enough venting. Is there a touch screen that is available that already has this type of connection built in. i have searched but i cannot get a clear answer. Thank you in advance for your response.
    Elsewhere
    Uhhhh.
    Xenarc screens can connect directly to a vehicle's electrical system (assuming it's 12v).
    Lilliput screens include an egg-shaped regulator to allow this, as well, although I understand that the "egg" is pretty low-quality...
    Or are you wanting to plug the unit into a cigarette lighter/power jack?
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    I thought I remembered the Xenarc's coming with a cig adapter also.
    Jan Bennett
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    is cutting off the cig lighter plug really that big of a deal?
    I actually like that they come with a prewired plug, because it allows you to test everything out before you hardwire it in.
    some people will never be happy. if they included a power cable with stripped ends then people would complain that it wasn't stripped enough, others would complain that there's no ring terminal on the ground wire...
    just be happy they designed it to run on 12v and include a power cable that's easy to modify for custom installs :/
    _
    Mar 2004
    Little Elm, Texas
    others would complain that there wasn't someone included in the box to wire it all up for you.
    Jan Bennett
    May 2007
    Boston
    lol
