Results 1 to 10 of 14
Thread: Lilluput 619 Transflective - No VGA input
    Apr 2007
    London, UK
    Hello All,
    Could do with a little help. I have a Lilliput 629 Transflective touchscreen. When connected to my desktop, the screen works fine. I power it using the 12v rail out of the atx power supply.
    The Car PC specs are as follows:
    Opus Mini-ITX case 120w
    Commell LV-681 Mini ITX Board
    AMD Turion TL-60 2.0GHz
    2GB DDR Ram
    160GB SATA HDD
    Slimline DVD-RW
    When I connect it to the VGA on the carpc, I get VGA signal whilst the system is loading up (before all the windows stuff kicks in), and then the screen says "no input signal".
    I've connected the carpc to my in house desktop monitor and it works fine, no problem with the vga signal.
    Has anyone else had any similar problems? I can only think that the lilliput isnt getting enough power from the powersupply... wanted some opinions before i start digging....
    amk136
    Mar 2006
    Colorado, but Canadian!
    resolution isnt supported.
    Change to 640x480, 800x600, 1024x768, or the actual supported resolution of 800x480
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2007
    London, UK
    hey 2k1,
    tried it on 640x480, 800x600 and 1024 x 768. same problem. I dont have the option to set the resolution to 800 x 480. can i force it to display this resolution.
    have you had any experience with the lv-681? or know of any known faults etc.
    thanks,
    amk136
    Low Bitrate deeznudts's Avatar
    Oct 2007
    Trenton, NJ
    I have the same problem. But only sometimes. I'm still in bench test mode, but I'd hate for this to happen once installed. I've seen older posts about the VGA setting, but I've checked mine and it's set correctly. I would love to know how you make out or what you find out.
    Mar 2006
    Well my older Commell LV-670m has strange video problems sometimes. But changing resolution and refresh rates, help.
    Instead of trying different resolutions, try some new refresh rates as well. 60Hz to 75Hz is normal. But you can try anything just to see if it helps. And there is a atulity around that will force strange resolutions (like 800x480).
    Apr 2007
    London, UK
    Hello All,
    I seem to have stumbled upon a solution for this:
    For the Bios and Dos stuff before the windows stuff kicks in
    This is quite simple, go into your bios, and you should be able to select the type of monitor you are using and set a resolution for it. In mine I set it to CRT + LCD at a resolution of 800x600.
    "No Input Signal" when windows stuff loads
    Once I got the screen working consistently during bios load up, I simply reinstalled a fresh copy of windows. Once windows was installed, If you look at device manager, there should be a question mark next to the VGA Adaptor. I simply did not load the correct driver for the VGA adaptor as this was the culprit. I have just left it as it is using the standard generic windows version. I get 32-bit colour and 800x600 resolution which is fine for me.
    2k1, thanks for the help and advice.
    amk136
    Apr 2007
    London, UK
    Ok,
    Yes the screen works but it has led to 2 problems i didnt see coming....
    1. hibernation doesnt work, vid card needs the correct drivers in order to hibernate
    2. videos dont play properly.
    It has got something to do with the refresh rate and i will be investigating that later on tonight and will post the results up on this thread:
    hibernation tab missing
    amk136
    Sep 2007
    Corona, Ca.
    Ok, I seem to have stumbled onto the same problem with my monitor.
    Everything was working fine until I started powering the monitor from my pc power supply. (M2-atx) Never a single problem until then.
    So I plugged the AC power adapter back in and now it still shows the BIOS and windows XP starting, then goes to "no signal".
    If I boot up with an old CRT monitor it works fine. After boot up, I can unplug the CRT and plug in my LCD and it works fine. When I go to restart, the same problem comes back.
    I did not find anything in my BIOS that allowed me to change the resolution, only the type of monitor (VGA). The resolution in the display settings is the same as my supported resolution on the LCD (1024x768)
    How and where do I check the refresh rates?
    I have not tried reinstalling Windows. If I do that, will I have to reload all my programs and data?
    This is so frustrating, the last time the pc was started it worked. I changed the power source for the screen and now it doesn't.
    Please help
    Edit: Sorry, this is not a Lilliput, but the problem is identical. I am using a Litemax 10.4" LCD.
    Getting quality goods and service is like buying oats. If you would like clean, fresh oats you must pay a fair price. If you would like oats that have already been through the horse, those are a little cheaper.
    Sep 2007
    Corona, Ca.
    Ok, I figured out how to change the the refresh rate. I changed from 60Hz to 75Hz with no change.
    Sep 2007
    Corona, Ca.
    Uninstalled and reinstalled the video drivers, no change.
    Found in the BIOS where to change monitor from CRT to LCD, no change. Still have not found anything in the BIOS about resolution.
  1. Cheapest Display with a VGA input?
    By mp3stang02 in forum LCD/Display
    Last Post: 11-07-2002, 05:56 AM
  2. Replies: 1
    Last Post: 09-30-2002, 10:41 PM
  3. notebook LCD 2 standart VGA input wiring
    By valiokaz in forum General Hardware Discussion
    Last Post: 06-06-2002, 11:53 AM
  4. Replies: 3
    Last Post: 02-08-2002, 12:25 AM
  5. 13.6" LCD for sale, accepts VGA input and runs off 12VDC
    By DodgeMp3Enabled in forum Classified Archive
    Last Post: 01-04-2001, 11:58 PM
