Here's how it worked for me, for the 945 Intel mobile graphics and for a Lilliput 629 monitor.
- Install a display driver that does not already contain a 800x480 resolution. I just took the latest regular driver from the Intel site.
- Run DTD Calculator, and see if the two buttons in Registry Hack are active.
- In the Calculation tab, select the standard timing 720x480.
- In the Registry Hack tab, press More if needed, press Get Calculated, press Create Modeline, press write DTDs to registry. Reboot.
- Display properties, click to show all modes, select the 720x480 driver and see if it
displays ok. You have now established the ability to add new resolutions with DTD Calculator.
- Run DTD Calculator again.
- Start with the 720x480 template in the Calculation tab, change the five most top left values to: 29.5 (MhZ), 800, 816, 880. 936. (It's everything 80 pixels more than before and a bit higher clock to get 60 Hz).
- Repeat the rest of the procedure with the new 800x480 resolution.
