Results 1 to 5 of 5
Thread: TM-868 backlight
    Feb 2008
    TM-868 backlight
    Hi!
    This might be too stupid question but...
    I just bought an used 8" TFT (SGDQ TM-868).
    It didnīt have AC/DC adapter so i bought a 12V, 1000mA adapter with + in center.
    My problem is that when I turn it on, the screen stays black. Iīve tied almost everything but still..nothing. The power light is red. Shouldnīt it be green anyway?
    Jari, Finland
    Low Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    mine just went out i have a shark 8" screen i bought from gooddeals18 it was working fine and it just went black. The wierd part is that the touchscreen still works when i touch any part of the screen my computer still responds. ie play, pause, next etc etc
    Jan 2007
    Szeged, Hungary
    That power seems to be quite low.
    This type of monitor needs around 10W at normal working. Directly after switching on, the current runs above 2A for a short time (because charging capacitors), and perhaps your adapter is not strong enough to provide this, therefore voltage falls.
    Run it from the PC power supply at home or
    buy a cheap 12V 3A stabiliser IC (eg. 78T12) instead and drain the car battery (with engine on, of course).
    Jan 2007
    Szeged, Hungary
    Quote Originally Posted by Morpheus2010 View Post
    Perhaps just the backlight is off. Try to enlight it by a strong source of light. Do you see any sign of picture? Use a picture with high contrast.
    Jul 2007
    orlando
    All I see is when i turn it on is a flash and the screen stays black. i've even plugged it up to a ac adapter. The screen was working for a while before this happened. only the touchscreen works now. thanks for the help
  1. TM 868 screen went dark
    By elstev0 in forum LCD/Display
    Last Post: 08-15-2007, 07:23 AM
  2. tm 868 calibration
    By YetiMan in forum LCD/Display
    Last Post: 04-23-2007, 04:34 PM
  3. tm 868 8 inch monitor and some other stuff
    By sti robot in forum Classified Archive
    Last Post: 10-25-2006, 11:53 AM
  4. wtb ebay tm 868 touchscreen
    By selmerguy in forum Classified Archive
    Last Post: 07-05-2006, 05:30 PM
  5. FS: 8" TM 868 recessed in 2000 Honda Accord (Ready to go)
    By wu4607 in forum Classified Archive
    Last Post: 05-17-2006, 01:32 AM
