another interesting note that maybe someone knows the cause. On the way home from work, screen was blinking like normal. After about 30 minutes it finally settles down and stops. After that, I decided to try adjusting the resolution and refresh rate. Set resolution to 800x600 and my only choice for refresh rate was 60Hz. Anyways as soon as I set the resolution, the screen starts flashing again. Coincidence?
I'm about to take a picture of the back of my shark 8" monitor so bbalazs can tell me which exact wire i need to do what ever to.
The backlight unit is a part of the display, that is TOTALLY independent of the part that is responsible for the picture. It is wired with power, GND, enable, dim. This unit contains some electronics (usually a controller IC) and switching elements, usually transistors of FETs and a transformer, that produces the high voltage needed by CCFL or CCFT (cold cathode fluorescent tube/lamp - the same thing!). That voltage is approx. 1500V at ignition and about 800V during operation. The primary part has an overcurrent protection, and very likely this is the cause of flashing.
When one changes resolution, the enable is inhibited for a short time, therefore the flashing could start again.
If you are not familiar this things, I suppose to see the service.
Alopecia perniciosa
ok so I'm pretty sure I know that part your talking about, but if Morpheus is gonna post up a picture, I'll hang on so I know what I'm doing is 100% right.
ok sorry for the late reply but gooddeals18 finally replied back to me after 4 emails. They told me to send the monitor back for exchange.
