Results 1 to 7 of 7
Thread: Out of Range error
    Jan 2008
    Out of Range error
    So I fired up the ibm t42 laptop carputer that I am still trying to set up and everything booted fine on the screen. A couple of minutes later all of a sudden the screen goes blank and a message appears on the lcd saying out of range. Anyone know why this is happening and how to fix it? This is a brand new in dash lcd monitor that was working for a day or two so seems strange why it would start happening all of a sudden. It happened in the early morning but the temps weren't too cold for california weather. Tried searching but didn't find anything that was exactly the same problem.
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    how is the monitor connected?
    check us out at: www.neonboombox.com
    Jan 2008
    out of range
    I have the monitor connected with vga cable and usb for the touch screen. Power is connected to the same harness as my clarion head unit.
    I found a thread where people were saying I should lower the refresh rate. This may make sense because I used a custom resolution setting in powerstrip in order to get the 800x480 resolution. I'm going to try and lower the refresh rate to see if that solves the problem.
    Jan 2008
    refresh rate
    So I look at what my refresh rate is set at and it says 60 hz. I decide to lower it to see if that solves the out of range problem. I tried 57 hz and then 50 hz but still get the same error on the lcd screen. Question is, how low should I set the refresh rate? Should I just go back to 800 x 600 and forget trying to hit 800 x 480?
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Out of range means you have one or more settings beyond what the monitor is capable of displaying.
    The usual culprit is the refresh rate, but size can also cause the same behaviour (depends on the monitor).
    Hook your puter up to a regular crt monitor and see what it is running. Adjust the settings and try the in dash until you find something that works.
    You can start at 800X480 and a refresh around 70-72 hz to start with (that's where my lili likes to be).
    Be aware that there are alot of settings in powerstrip you have to get right for a custom resolution to work properly.
    If you can't find a rate that works, you may just have to stick with 800x600..........
    Leonardo Da Vinci
    Jan 2008
    refresh rate
    Thanks for the reply! I think that could be the problem, instead of lowering it down I'll try and bring it back up to 70 hz and see what happens. Worst case, I think I can live with 800 x 600, just wanted to get it exactly right by trying to hit 800 x 480 using powerstrip. Got a response from the manufacturer to change it in the bios. I think I'd rather try and do it in powerstrip first.
    Powerstrip was a little hard to figure out at first, I ended up using one of their already set up 800 x 480 60 hz profile. When I tried to set it up myself by clicking the up and down buttons, I could never get it just right. And after choosing the profile you have to click ok and then move the slider to choose it again, then apply. Kind of confusing if you don't know what you're doing.
    Jan 2008
    powerstrip
    Okay I figured out what was happening although I do not know why. First off, I tried raising the refresh rate to 70 hz, but still got the out of range error. So I decided to just go back to using the 800 x 600 standard resolution, but still gave me the same error. Finally tried to switch it back to 1024 x 768 but the error still came on the screen! Then it came to me. The out of range error is coming on right after powerstrip loads to the system tray. So in desperation I remove the powerstrip program and whoola! No more out of range error. I cannot tell you why it doesn't like the powerstrip program but now it works without the error so I'm just going to be happy the way it is.
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. RRMobile Resurrection
    By VorTechs in forum RR Plugins
    Last Post: 04-04-2008, 10:22 PM
  3. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  4. MCI error 261 and 263
    By genesis66 in forum Road Runner
    Last Post: 12-21-2007, 02:59 PM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
