Results 1 to 10 of 19
Thread: Lilliput screen fro ebay what do u think?
    Newbie jaymatic21's Avatar
    Aug 2005
    NY
    http://cgi.ebay.com/New-Lilliput-7-T...QQcmdZViewItem
    The only thing im worried about is the vga connection is this ideal?
    http://img215.exs.cx/img215/3613/jay.gif
    Either love me or leave me alone
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    I took a few minutes to carefully look over the ebay link that you provided.
    From what I can see, this unit is about identical to the Lilli629 that I use in my car.
    Same wattage, dimensions, accessories...except that I paid $245 from mp3car strore in early November '07.
    I like mine a lot, but my lack of experience didn't prepare me for the fact that the touchscreen overlay is filmy and definitely reduces the quality of screen images. I'm older, and I would prefer clarity...
    Yeah, that funky adapter fitting for vga/other inputs is the same as mine. Works ok and not too unwieldy. See my pics; I have goosenect mount, so those extra unused inputs are cable tied, but still visable. Can't bring myself to cut 'em off, as other inputs COULD be used some day.
    I found this in the LCD / Display forum:
    http://www.gooddeals18.com/product/SHK1040
    Check the LCD / Display forum for that one; a lot of responses 'cause it sounds pretty hot. Even if I install my current Lilli in the dbl DIN spot in my dash, I may buy one of those 12" monitors. I like to be able to see and enjoy what's on my screen...
    I have only been using my Lilli as a basic screen; never set up the touchscreen part, but I plan to plug USB from my Lilli into front-seat USB hub, then load Lilli touch app - probably tomorrow. I have been using the front end, Street Deck that I bought from mp3car store - and I'm ready to use it in touch mode...
    Happy carpc'ing!
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    That's an eby 701. Search the forums as there are many reviews and comments on it.
    It's very popular due to it's bargain basement price.
    I have one and it's taken alot of abuse, still works fine.............
    VGA connector has never been a problem other than my not having the barrel connection tight enough one time.
    Leonardo Da Vinci
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by greatwhite View Post
    The model shown is the older eby 701. The newer one is brighter.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Aug 2005
    NY
    brucedog do you have pics of it installed how was the install straight up? any custome mods have to be made to fit it in?
    Oct 2007
    Philadelphia, PA
    See where my name and carpc specs are on this reply?
    Now, look down below it, and you can see my pictures.
    Click on my pictures to view. c,lick on the picture to see enlarged.
    A picture is truly worth 1000 words.
    Happy CarPC'ing!
    Oct 2007
    Philadelphia, PA
    Oh, the gooseneck mount has a tab that slides into the notch on the rear of the Lilli, then can be hand tightened - easy.
    I had to put the tab on the gooseneck on my grinding wheel a little bit as it was oversized for Lilli notch - no trouble.
    Happy CarPC'ing!
    Low Bitrate lor109's Avatar
    Mar 2004
    Quote Originally Posted by HiJackZX1 View Post
    Why is the newer brighter? LED Backlight? Any ideas?
    Nov 2007
    It is exactly the same as mine.
    The box too. When i first received it, after looking on the box, i thought the shop must of gotten the order wrong.
    The connections it uses are fine.
    Not to sure about much more then that though as i haven't put it in my car as of yet.
    Mar 2006
    Colorado, but Canadian!
    I have used this screen for 2 years now. Only thing is I blew up my 800x600 resolution support, and I am not sure how. I am on my second touch overlay. Both things my fault. I have opened the thing up down to the bare LCD panel (not just circuit and LCD block, but I mean taking it apart to the see through glass panel, backlight and so forth, a few times, and put it back together and it works. I dropped a textbook (3 inch thick textbook) right on the LCD and cracked the upper corner, but the pixels all still work except for directly under the crack (didnt leak out everywhere)...
    So yeah. I have used and abused this thing and I would buy it again. It was $200 including shipping and customs from Hong Kong when I ordered it 2 years ago.
    1.9in x 2.9in -- 47mm x 73mm
  1. Troubleshoot Sync Mini Mac Lilliput screen
    By Zedrush in forum MacCar
    Last Post: 03-27-2007, 08:45 AM
  2. Starting up lilliput screen without button PCB?
    By Indust in forum General Hardware Discussion
    Last Post: 03-02-2006, 10:10 PM
  3. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  4. 8" Lilliput question, extracting sound and screen rolls
    By clean customs in forum LCD/Display
    Last Post: 06-30-2005, 11:10 PM
  5. FS - (New) Lilliput touch screen replacement
    By calvincbr in forum Classified Archive
    Last Post: 01-27-2005, 11:12 AM
