Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
Thread: New Lilliput 629 Native Resolution?
  1. #41
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by InsaneQc View Post
    the first version of 629 in my first reply has 640 x 480 True native resolution. and I want to know if the 2nd one has the same issue OR it's a real 800x600 native
    I doubt it. My 669 specs also state that 800x480 is native, but it doesn't work at all. Period. 800x600 is probably the true native resolution.
  2. #42
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Hmm have you read the whole thread ?
    629 and 669 are both 7" wide monitors > i think native 640x480 is impossible, there is no wide LCD panel with 4:3 pixel aspect ratio on the market. the native resolution of LCD panel should be wide like 800x480, 848x480, 1024x600 or similar - but there might be an idiot hardware limitation of the controller board where the real native resolution is not supported, only the 640x480, 800x600, etc...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  3. #43
    Aug 2010
    Ok alright so I am gonna buy the 629 For DVI-D Input.... Thanks!
  4. #44
    Mar 2011
    I've recently purchased a used 629 from Ebay and having problems with it as well. It displays the resolution as 640x480 for me too... I was actually able to switch to 800x480 however the monitor only displays the part of the image and the rest I need to scroll to with the mouse.
    (It seems to be working fine in 800x600 and 640x480 but the image quality is far from great because of the resizing.)
    I'm wondering if replacing the controller board on the monitor fixes the issue. Otherwise it's quite unusable, and I don't like to end up purchasing another monitor which could easily act the same way.
  5. #45
    Dec 2006
    Quote Originally Posted by KoGa View Post
    Scroll with the mouse seems like pan and scan. I think it's the operating system that does that, I can't imagine it's the monitor. What OS do you run, Windows XP?
    I don't think the monitor can do this.
    Which 629 do you have? LED or CCFL? The LED one have the panel off-center in the bezel.
    Some LED based 629 are truly screwed up in that the can not display a clean 800x480 pixel accurate. The panel resolution is 800x480 but the controller forces an internal resample to 640x480.
    I don't know about swapping controler boards, but where would you even get one and how would you know that it's better. LED controller boards and CCFL controller boards are not compatible.
    I think all or at least most 629 misreport the resolution as 640x480 on the on screen menu even if 800x480 pixels are displayed.
  6. #46
    Mar 2011
    Quote Originally Posted by JuniorGeezer View Post
    Yes it's Windows XP and the LED of the monitor version running from my laptop while being tested (Nvidia 8400M GS chip). I was suspecting the OS as well but could not find any settings for this behaviour, and it only does this in 800x480, no other resolution.
    Quite dissappointing Thankfully I bought it used so did not pay the full price.
    I remember seeing replacement boards on mo-co-so or some other site but they're not cheap, above 60 bucks.
  7. #47
    Mar 2011
    Ok I've found the data sheet for the display built into the monitor. Maybe somebody can figure out the correct timings and calculate a modeline for Linux?
    AT070TN83.pdf
  1. Lilliput 629 stopped working
    By numbr_9 in forum LCD/Display
    Last Post: 10-03-2007, 11:33 AM
  2. Lilliput 629 image problem
    By heuninck in forum LCD/Display
    Last Post: 01-03-2006, 05:56 PM
  3. Are the Lilliput 619 and 629 cases interchangeable?
    By Darek85 in forum LCD/Display
    Last Post: 10-27-2005, 03:01 PM
  4. Lilliput resolution problem
    By greddy0 in forum LCD/Display
    Last Post: 11-24-2004, 03:51 PM
  5. Lilliput Fuzzy screen, resolution problem?
    By vcbb5 in forum LCD/Display
    Last Post: 07-04-2004, 01:13 PM
