Results 1 to 7 of 7
Thread: Need help hacking 2 17" laptops with 1680x1050 native screens
    Newbie Slimline's Avatar
    Nov 2004
    I have 2 Compaq X6000s that are basically dead - I want to harvest the parts from them and use them however possible. However, I know some LVDS backlight inverters are compatible with selective screens. Can anyone recommend a good place to start?
    Jan 2007
    Szeged, Hungary
    The first thing to do is to read the type ID from the back side of the screen. That determines all possibilities to drive. Search datasheet or at least pinout for that.
    Do not bother too much about the backlight, that is independent.
    Is it two-tube or four-tube version? (how many white duoble-pin connectors are on the inverter panel?
    Alopecia perniciosa
    Nov 2004
    Will post pics when I disassemble, unable to get a response from HP about it
    Jan 2007
    Szeged, Hungary
    HP, Compaq are BIIIIIG companies. Main function is to produce and force you to buy.
    They won't do anything for you...you just waste your time...
    The display is more likely a product of another company.
    If you got the type (eg: lm174sn1 or so - manufacturer code, size indicator, additional type codes) search the internet. I strongly believe, it is a double-LVDS drive with 8 twisted wire pairs...
    But if you want to use it as a monitor, you have to get a VGA-LVDS converter board, eg. from an LCD monitor with broken display.
    Alopecia perniciosa
    Nov 2004
    There are some VGA-LVDS converters on ebay I was looking at - $35 apiece. I may do that if it is the easiest thing to do. I'll have these taken apart this week, I need a new set of screwdrivers first.
    Jan 2007
    Szeged, Hungary
    Be sure about the number of pairs, because there are lvds converters for smaller laptop displays, that works with 4 pairs, and the converter for tft monitors that has 8 pairs.
    Alopecia perniciosa
    Nov 2004
    Ahh i see - yeah these are 17" so they're gonna be 8-pin. Going to gun show, bbl to dissect.
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. Touch screens work with laptops?
    By seakykr in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 10-03-2006, 01:27 PM
  3. 2 nice laptops without screens fs
    By outragis in forum Classified Archive
    Last Post: 06-03-2003, 08:50 PM
