Results 1 to 3 of 3
Thread: 2008 Xenarc 700tsv 800x480 qstn
    Oct 2007
    Can anyone with the new '08 700tsv screen confirm that it is capable of displaying native 800x480 resolution? Does it report this as 640 x 480 on it's OSD for you?
    There was some concern that the 705tsv initially shipped with a less caapable graphics chip, that only supported certain 4:3 resolutions and couldn't do true 800x480. I'm trying to get native resolution out of my mac, and despite all my efforts it reports a native resolution fed to it as "640 x 480" and text looks bad (thin black lines are "washed out" by neighboring white areas).
    So either I haven't yet found the magic timings needed for clear 800 x 480, or the new 700tsv screens suffer just like the 705 models
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    Yes, I have an '08 800TSV and I run it at its native 800x480. Xenarc's website specifies a very specific set of signal timings to get the exact native resolution through a program like PowerStrip. Both my computer and LCD refer to this resolution as 800x480.
    And I tested that it truely is native by setting my background to vertical and horizontal one pixel wide black/white lines. No moire patterns. (Tried the '08 Lilliput 7" widescreen just previously and returned it because no amount of timing tweeking could get a perfect 1 pixel to 1 pixel resolution)
    Have you tried the magic timings & xenarc's website?
    Oct 2007
    Ah - THANK YOU for confirming the resolution capabilities of the new 700 tsv.
    I have tried to use the timings specified on Xenarc's FAQ, but there is a bug in the DisplayConfigX tool (a MacOS equivalent to powerstrip) that doesn't allow me to match them exactly (it keeps resetting the vertical front porch to a "safe" value other than what it needs to be). I guess I'll have to try some other resolution tweaking tools.
    Thanks for the idea of the 1 pixel lines as a moire-check. I'll have to give that a try once I think I've got it figured out.
  1. Xenarc 700TSV @ 800x480 on a Mac mini?
    By MacVroom in forum MacCar
    Last Post: 04-14-2008, 08:07 AM
  2. Replies: 0
    Last Post: 02-05-2008, 12:43 PM
  3. 2008 Xenarc 700TSV 800x480 problem
    By Salmizar in forum LCD/Display
    Last Post: 11-16-2007, 10:06 AM
  4. MII1000 and Xenarc 700tsv 800x480 possible?
    By strvngartst01 in forum LCD/Display
    Last Post: 05-25-2007, 04:46 PM
  5. Xenarc 700TSV 800x480 Support
    By auto_robotics in forum LCD/Display
    Last Post: 08-27-2004, 01:33 PM
