I realise this thread may be dead, but for anyone looking at this thread, I think you have all over engineered this answer. It is much easier, and much more reliable to use a solid state switch. You can make a solid state switch with a basic 555 timer board, and by using either changes in resistance or capacitance create a grounding or
power trigger to match any second or millisecond count you so desire. If any one needs help with this you may contact me. Or respond to this post.
You can build a 555 timer circuit yourself very easily to suit a specific application, or you can buy 555 timer boards that you can adjust timing on them very cheaply. Just as an example based on this post.
The screen is changed via a momentary switch. To send a Momentary (+) signal to the Screen you would connect the 555 timer in parralel to the reverse light switch. When you go to reverse the signal would go to the 555 timer, and start it's count down. You can set the 555 timer to be a one shot timer. So what that means is. No matter how long your in reverse it will only send the momentary signal once, until the timer is reset. Once you leave reverse it can be set to trigger again and switch your monitor back to the other source. Than you don't have IR remote interference, or mechanical switch or relay problems. Also the 555 Timer works on milliamps of current, which is all you should need for a momentary switch circuit of a monitor anyway.
As far as the guy with the blue tooth thing, the same set up applies, and he could adjust the timer to emit a 2 second pulse. Hopes this helps people in the future. 555 timers are very low power, very easy to experiment with, very easy to unsterstand once you play with one. and are also very cheap and reliable.
Also something I forgot. Using a relay will give you voltage spikes that may damage sensitive electronic equipment. The 555 timer sends a square wave signal, that is spike free, and safer to use.
