Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 86
Thread: EBY701 questions and opinions!!!!!!!!!
  1. #51
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Robby BMW View Post
    Hi to all,
    I've received an invitation to participate in this discussion by HiJack, and I've just finished to read all the posts.
    Perhaps this could be helpful http://www.freewebs.com/billymcbunter/
    I love you Robby..... When it comes to PIC and finding info on it, your the greatest. I knew you could help with this issue........
    PS: um, can you translate this into newbie terms? Lol, I dont understand it at all.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #52
    Jul 2007
    Miami
    OK I downloaded everything and it looks like this requires AutoDesk DWG to open and read. Be ready this download is 193 MB, but from what I can read its free.
    What is the EPC file Robby, what does it do, how do you open it?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  3. #53
    Jul 2007
    Miami
    OK, I started looking and reading and trying to understand it better. It looks like its a circuit for controling 2 relays, its basically a complicated version of what you have proposed Katit.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  4. #54
    Jul 2007
    Miami
    Quote Originally Posted by katit View Post
    Ok. Here is schema person on other forum designed (after 3 different ideas with microchips)..
    Capacitor value will specify pulses duration C(in Farads) = T(time needed in seconds) / R(resistance of relay coil)
    Two tiny 12V rated relays could be used
    It works like that. When voltage supplied - capacitor will charge and second relay will be activated. As soon as capacitor charged - relay will deactivate. When voltage removed - capacitor will discharge and activate second relay.
    Is this something you have tried? What capacitors do you have to use?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  5. #55
    Apr 2007
    St. Louis
    I didn't try it yet. Capacitor should be calculated depending what relay do you use (resistance of coil) and how long pulse have to be. You can build one quickly using 2 automotive relays and 1 500uf capacitor.
  6. #56
    Jul 2007
    Miami
    Where is the capacitor on the drawing? I can only make out the 2 relays........ Tommorrow Im going to hop over to radioshack and get the capacitor, I already have the relays.....
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #57
    Sep 2007
    The EPC file is a diagram of the PCB board. The usually green composite board that has the circuit imprinted on it. If you go to PCB123's web site, you can download their circuit design software, and open this file if you want to look at it. But it is mostly for submitting to PCB123, so their computer can make the circuit board for you. Than all you do is buy the componants and solder them to the premade board.
    P.S. the capacitor in the drawing is ( +---||--- ) between the two relays at the top.
  8. #58
    Jul 2007
    Miami
    Quote Originally Posted by triath5147 View Post
    From your opinion... which set up is best? The PIC process seems to take time and cost more, and doesnt insure that the screen will flip correctly. The relay way has the same issue, but much easier to buy and cheaper.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  9. #59
    Jul 2007
    Miami
    I bought the 2 relays..... they both have a coil resistence of 56 ohms +- 10 %, what capacitor do I need? I found a 220 UF one.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  10. #60
    Apr 2007
    St. Louis
    Quote Originally Posted by HiJackZX1 View Post
    I would try what you have and see how long is your pulses. You can use bulb on that circuit to test
  1. Replies: 6
    Last Post: 12-01-2006, 05:32 PM
  2. My Planned System, Opinions Needed
    By Wilsman00 in forum Newbie
    Last Post: 10-14-2006, 05:30 AM
  3. Lots of questions.. long post.
    By rach in forum Newbie
    Last Post: 11-13-2004, 11:53 PM
  4. NewBie - Looking for opinions & A few questions....
    By DaveP in forum General Hardware Discussion
    Last Post: 07-11-2004, 06:19 PM
  5. Additional questions about LCDs: Is 400 nit too bright?
    By khiser0001 in forum LCD/Display
    Last Post: 05-06-2003, 08:13 PM
