Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
Thread: Touchscreen pointer jumps to right edge
  1. #31
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    With my install all 3 Lilliputs are in very space confined areas..... I have not figured out the setup I will use.... I was thinking of putting a thin fan at the top and the bottom... one will blow air in, the other out, or should I have both blow in? That will be done to the sunvisor screens. The Lilliput in the dash I was thinking of making small airducts on the back were the screens vents are and have a large fan connected that draws air out.... or maybe I should do the same were it draws air in and another fan draws air out... What do you guys think?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #32
    Jul 2007
    I had the same screen and it did the same thing. Seemed to only happen when the screen was cold. after a few minutes, it would work fine. I finially broke it trying to fix the screen. Now I have a xernec and couldn't be happier.
  3. #33
    Mar 2008
    Quote Originally Posted by FusionFanatic View Post
    if you don't even know the brand name of the monitor, do you really need to worry about it's warranty? if you ever wanted to file a warranty claim on it, chances are you would have to pay to ship it overseas to Asia to have any work done on it (the shipping alone could cost more than the monitor itself ).
    Update to this..
    Have to give some credit for HCCL as they mailed me few days ago and turned out that they would have paid the shipping costs also if I had returned the screen.
  4. #34
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Quote Originally Posted by sniiki View Post
    I really wonder why these small panels run so damn hot. I mean this get REALLY hot and all desktop monitors stay really cool, barely warms at all.
    Maybe I should install thin fan on the back side..
    Big monitors have much more surface area to disipate the heat.
    And much bigger cases which hide the true extent of the temperature to those touching the outside of the box.
    Go inside on and you will probably find parts that get as hot as any lilli does.
    The quality of the touchscreen overlays in my experience, and many others on here is generally not fantastic. And is a well known issue. Leaving the car parked in direct sunshine on a hot day is also not doing your screen any good as incar temps can easily soar past 100F. Which does nothing for the stability of the adhesives used.
  5. #35
    Oct 2007
    Quote Originally Posted by ShawJohn View Post
    Sounds to me like the same problem the 7" lilliputs get. The touchscreen overlay becomes delaminated as the glue holding it all together melts when the screen gets too hot. Its starts off erratic, then eventually the whole right hand side of the touchscreen will stop working. This problem was acknowledged by Mo @ Lilliput UK Tech support.
    Well known fault on Lilli's. Only known fix is replacement overlay, costs about £40 IIRC from Armen @ digitalww.com
    You'd have thought screen would have come on more than they have in the last 4 years!
    I think my lilliput is suffering from this problem. Suddenly the right hand side is not working properly. The x coordinate gets registered almost on the center of the screen, the y coordinate gets registered correctly. After calibration, the linearization screen shows "bumps" on the right edge of the screen.
    Is this behavior what you were referring as the problem Lilliput tech acknowledged?
  6. #36
    Aug 2004
    On the edge!
    yes, and the linearisation will change from time to time to so you need to leave a shortcut to the calibration app on the left hand side of the desktop just incase you need it.
  7. #37
    Aug 2004
    On the edge!
    Maybe we should get all the lilli owners who had this fault get together and mention 'Class Action' to Lilliput? Maybe if we get enough people together they will change their minds!
    Somewhere on one of my PC's I have an email from Mo @ Lilliput(UK) which acknowledges that there is a production/design problem, he refused me a new free TS though. But he did offer to look at it if I sent it in, I didn't want to do this though as I didn't have another screen to use in the mean time, and at the moment, my current screen isn't that bad - touch wood!
    I have had the original supplier replace it twice though.
  8. #38
    Oct 2007
    count me in for whatever you need if you are going to contact lilliput again.
    In my case the calibration doesn't help. No matter how many time I run the linearization utility it always leaves a "bump" on the right side.
    One thing I noticed is that using your finger works better than using a stylus. It seems the extra surface pressed by the finger helps the screen to determine the correct coordinates. The stylus gives very erratic results.
  9. #39
    Mar 2008
    Received the new panel from China last week. Wasn't the same kind as the old one but size was exactly same and fitted nicely. Uses same drives.
    Came really well packed too.
  10. #40
    Oct 2007
    solution
    hey i ordered one too but unfortunately the panel was broken when i recieved it....not a big deal though as my problem was only the controller! thank god.....but now my vga port wont work so i am trying to figure out how to extend my primary lcd cable to the touchscreen...any suggestions would be great....thanks and good luck everyone
  1. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 09:02 AM
  2. Motherboard and Touchscreen don't love each other...
    By kevpriest in forum General MP3Car Discussion
    Last Post: 07-27-2006, 10:25 AM
  3. touchscreen problem drives me nuts ! plz help
    By diskey in forum Input Devices
    Last Post: 04-24-2006, 10:15 AM
  4. touchscreen edge not responsive workaround
    By [H]Bugster in forum LCD/Display
    Last Post: 01-13-2004, 02:33 AM
