Results 1 to 5 of 5
Thread: Lilliput connector does not fit
    Mar 2008
    I just got a Lilliput 7" eby-701. The cable that connects it to the PC is two pieces, but it does not connect itself. Here are some pictures to illustrate:
    The part that is circled in red is too fat and will not fit into this:
    Has anyone else seen this? Should I just file down the plastic I circled in red to make it fit?
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    I have this same monitor, look closely at each end and you'll see a little arrows. Make sure the arrows are facing each other. This will allow for them to connect together with ease!
    Phil
    Mar 2008
    Quote Originally Posted by funkyphil View Post
    Phil
    Thanks for the reply, but that is not the problem. When I don't have them lined up together, and i try to connect them, the black plastic pieces don't even touch eachother, and I can still see some of the silver connector. When I do line them up correctly with the arrows, the black plastic stops it from going any further. I can physically see the black plastic shroud is wider in diameter than the hole it's trying to go into.
    Mar 2008
    I finally got it working! I took a knife and cut out a little bigger hole and it slid right in. Plugged it into my computer and the found new hardware wizard popped up right away!
    It's a simple fix if it doesnt fit. The plastic is very soft and will slice right off with a sharp tool.
    Sep 2007
    CHI-TOWN
    That is Awesome! I was just about to tell you to see if you were able to trim a little of the rubber / plastic away. Good job, have fun and come back if you need further help!!!
    Phil
  1. Replies: 118
    Last Post: 10-22-2010, 03:05 PM
  2. HELP! - Lilliput Problem, Black Screen, No Picture
    By nfsp_trans_am in forum LCD/Display
    Last Post: 06-17-2008, 06:28 PM
  3. Help Please, no display on Lilliput EBY701
    By notuptodateguy in forum LCD/Display
    Last Post: 12-26-2007, 11:08 PM
  4. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 03:58 AM
  5. AC-DC Adaptor fit Lilliput ?
    By Danneman in forum LCD/Display
    Last Post: 06-14-2004, 04:24 PM
