Results 1 to 3 of 3
Thread: Lilliput 10.4 Internal Wiring Question
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    If you've uncased your Lilliput 10.4", Model 1042, I could use some help. In disassembling mine, I accidentally (violently) detached the four small wires that appear to be for the touchscreen. They look undamaged. There are two yellow wires and two black wires. I need to reassemble the plug they go into, and wonder if anyone can tell me which wire goes where. Here's a picture of the wires -- in order as they come off the board -- plus the two plug components, plus the board they plug into.
    Click on the image to enlarge it.
    I know how to reassemble the plug, but I need to know the wire order. This may be common to all Lilliput monitors; I just don't know.
    Thanks for your help . . .
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    May 2006
    Simi Valley, CA
    Ha... i did the same thing with my first lilliput. I'm pretty sure they go in the order that you have it there. I don't think it matter too much anyway because it would correct itself in calibration.
    Apr 2007
    Atlanta, GA, USA
    Thanks, GiODi. I'll just hook it up as pictured and test it out. I appreciate the advice.
    I put your answer in the Everything You Wanted to Know About Your Lilliput FAQ.
  1. Wiring question...
    By atikali2000 in forum Newbie
    Last Post: 04-17-2008, 11:21 PM
  2. Question about wiring selection
    By rbsx in forum Newbie
    Last Post: 09-01-2007, 11:24 PM
  3. Replies: 2
    Last Post: 05-12-2007, 09:24 AM
