Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Best Motorized screen on the market?
    Mar 2008
    i got an audi a3 and i'm looking for tha best motorized screen on the market for my mini carputer...????
    Mar 2006
    Colorado, but Canadian!
    there isnt. They all suck to be honest.
    Also do you want 1-din or 2-din?
    With 2-din you are limited to the DWW-650 (or equivalent branded models).
    With 1-din you basically have lilliput and xenarc. Both are good. Xenarc has an auto-switch inputs for like a reverse cam from what I am told. The motor/worm gear in both of them will fail rather soon rendering your $400 to $800 screen useless or permanently ghettoed.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2008
    i was looking for 1 din... but if it sucks big time :-(
    so if i'm going for anothere solution(i would really like a clean look).... what would you recomend?
    Mar 2006
    Quote Originally Posted by mrzantos View Post
    <personal taste>
    The only way to get it to look clean is to make it look OEM which means a screen molded into your dash so it looks like the car came that way. I have never seen an OEM with a 1din flipout. It just looks cheap. Also when you press it, the screen will wobble or bounce back a bit which to me would be pretty annoying.
    So time, a regular screen, some epoxy, bondo, primer, and paint and more time, you will have best results.
    </personal taste>
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    you might also want to check the k301 and the k90 (both chinese) my k301 still works fine after 2 years!..(metallic gears instead of plastic that liliputs used to have)
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Motorized screens usually stick out a bit, so it definately does not look as neat and stock as a molded screen.
    Ive taken apart my k301. Inside, it has metal gears and looks very solid and well built to me. But the opening/closing sequence does not feel as smooth as the new motorized xenarc, or the pioneer/alpines.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Been running an indash for a couple of years, If you want an OEM look forget about it. But sometimes there is little options. I only had a one din slot and did not have fab skills. The indash was a good option, but does not look like it is part of the car from factory.
    Sound Stage
    Eclipse|MTX|Infinity
    imi
    imi is offline
    Newbie imi's Avatar
    Jan 2005
    I am in the same dilemna and completely agree with 2k1 here....its shocking that decent quality in-dash touchscreen done exist.
    Can you guys post your in-dash installs please.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    I got one of these, they are cheapish hong kong screens, but are a manual eject.
    one thing is they can swivel, like most screens they are average in high light.
    but im pretty happy with mine, it has 1 VGA and 2 video inputs too for cameras as well.
    http://item.b-billion.com/XDX/XDXP07...1D_billion.HTM
    its about USD $233.00.
    their automatic eject one can not swivel left/right, but has a tv turner as well..
    imi
    imi is offline
    Newbie imi's Avatar
    Jan 2005
    Quote Originally Posted by Woofnstuff View Post
    thx, can i see more pics of the screen installed. want to see how much it sticks out of the din slot when closed if at all..
    if i may say so, these do look better than the xenarc( that are twice the price) or am I missing something.
  1. 05 RX-8 custom fab install (motorized flip-up screen)
    By zenfe in forum Show off your project
    Last Post: 05-08-2009, 08:26 AM
  2. Motorized drop screen
    By AznRida in forum LCD/Display
    Last Post: 05-20-2007, 03:49 PM
  3. what I need is a motorized touch screen GPS
    By wasss in forum General Hardware Discussion
    Last Post: 03-16-2007, 09:41 AM
  4. 7" In-Dash MOTORIZED screen
    By myfob in forum General Hardware Discussion
    Last Post: 01-25-2007, 08:30 AM
  5. WANTED, Mp3car MTSVO-SC Fully motorized VGA Touch Screen.
    By cambo in forum Classified Archive
    Last Post: 09-06-2006, 08:01 PM
