Results 11 to 20 of 29
Thread: LVDS cable help
  1. #11
    Newbie Lucky13ESP's Avatar
    Feb 2006
    This page is from the user manual of the mobo. Available Headers
    They appear to be different from the LVDS header.
  2. #12
    Low Bitrate benedums's Avatar
    Jan 2007
    Eagan, MN
    what are the pin assignments of CN23 & CN18?
    Sailin
    ________________________________________
    CarPC Status:
    Planning.......[--------x-] 90%
    Parts..........[------x---] 70%
    Fabrication....[----x-----] 50%
  3. #13
    Feb 2006
  4. #14
    Feb 2006
    In the case that this is a 36 bit TTL output i've started matching up pinouts
    I'm matching like so:
    RA0 = R00
    RA1 = R01
    RB0 = R10
    RB1 = R11
    now for the trick part. I have these labels left over
    On the LCD
    CK (Dot Clock?)
    Hsync (Latch Pulse?)
    Vsync (First Line Marker?)
    OHP-
    ENAB
    On the mobo
    SHFCLK (Shift Clock?)
    FLM (First Line Marker?)
    M/DE (Display Enable?)
    LP (Latch Pulse?)
    ENAVEE
    Let the matching game begin
    Again, thanks for the help, I'm learning, albeit slowly
  5. #15
    Jan 2007
    Eagan, MN
    So is that from a motherboard or a controller board?
    It looks like they split up the TTL interface between two connectors CN23 & CN18 which is a bit odd... none the less since the LCD is +5V you will not need to use the +3.3V... The ENAB on the LCD is probably the ENAVEE, CK could be SHFCLK, not sure where the Hsync and Vsync will mate to on the controller. and NC = No Connect...
    I would be very surprised if this worked and didn't fry the controller or the LCD or both, so tread carefully.
    It's best to find a controller that you know is compatible with the LCD...
    Sailin
    CarPC Status:
  6. #16
    Feb 2006
    Thanks benedums. That is from the motherboard.
    Anybody else want have any insight. I may have to contact the manufacturers to assure compatibility.
  7. #17
    Feb 2006
    That was a fairly quick response from the manufacturer. Here is what they said.
    OHP-|????
    So I think the pin to pin mapping is basically done. (I'm going to ignore the last two entrys for now. One has to do with flipping the screen and one has to do with something else.) Now I need to source the proper connectors (I'm sure I"ll need some help). Then on to bigger and better things, namely a touchscreen controller and backlight inverter.
  8. #18
    Jan 2007
    Eagan, MN
    The problem with TTL is it's susceptibility to EMI and limited cable length (about 18" max). Which is why most mother boards that support LCD's have at least LVDS.
    There are some companies that make a TTL to LVDS adapter which will allow you to run the cable as LVDS and place the adapter next to the LCD with a short TTL cable to the LCD.
    you'll probably have the best luck searching for connectors and cabling on Digikey.com, Mouser.com and Google.
    Hirose makes some of the LVDS and TTL connectors that will work.
    Does you MB have a backlight inverter? some new ones do.
    If not those things can be found on the above sites as well.
    Sailin
    CarPC Status:
  9. #19
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Rob Withey View Post
    It can be made to work. I'm running an 18 bit TTL panel from an LVDS output using a Advantech PCM3540 LVDS receiver to interface it.
    Quote Originally Posted by benedums View Post
  10. #20
    Jan 2007
    Eagan, MN
    what he said!
    Sailin
    CarPC Status:
  1. Hardware Review: Custom LVDS LCD Cable by MotorCity
    By Giuliano in forum The Review Palace
    Last Post: 11-04-2010, 06:51 PM
  2. Building specific 40 pin TFT LVDS female cable to 20 pin JAE Female CON
    By JacquesB in forum General Hardware Discussion
    Last Post: 08-13-2010, 11:39 AM
  3. Alpine IDA-X001 and High speed cable woes
    By Lurkerlou in forum Car Audio
    Last Post: 08-13-2007, 08:59 PM
  4. Laptop TFT cable extension, strange problem
    By predator1 in forum LCD/Display
    Last Post: 06-27-2006, 05:08 AM
  5. M10000 network card cable not detected
    By warnockm in forum General Hardware Discussion
    Last Post: 01-04-2005, 09:02 PM
