Looks like you've got 9 differential pairs and some power lines.
you'll have a hard time trying to find an off the shelf cable that long that supports that specific pin-out and connector interface.
you could build one but you have to know what you are doing, if you can find a cable that has 9 twisted pairs and is around 28awg that might work for the LVDS and a 22awg pair would work for power...
Here is the LVDS cable I would start with...
http://www.spectra-strip.amphenol.co...token=20509059
Last you would have to find the correct connectors and then terminate the 28awg wire to them (which is a bit difficult)
Doing this will not be easy at all, without specific tools and material.
You could design the cable and have a company make it for you but that will cost $$$...
If you still want to waist your time with this, try searching on Digikey.com, Amphenol.com & Google for the parts.
Hirose might make a connector that mates to this.
Good luck getting parts too, requesting samples may be the best way to acquire them.
LinkBack URL
About LinkBacks
