I have a lilliput 889GL with the LCD panel out. I can take pics of those connectors, but I don't know if they are the same as the 809 or not.
From what I see, it just looks like different aspect ratios. I would think the wiring should be similar.
My generic LCD touchscreen cracked. I found a replacement that is nearly the same size. It is the touchscreen for the Lilliput 809GL. I need to know if the ribbon connector will fit with my current USB controller.
If you have pictures of the lilliput touchscreen connector or USB controller input please post.
thanks. greatly appreciated. ill assume that all lilliput connectors are the same.
