Results 1 to 4 of 4
Thread: Xenarc Ribbon Cable in a LinITX
    Jul 2006
    I damaged my ribbon cable (I think) on my LinITX TMR and was hunting for a replacement, but could not find one. The mp3car store sells one for a Xenarc, though. I counted the number of pins, and both have 40. I also emailed them requesting the width, to see if it would fit my connector. If these match, is there anything else I should look into? I was thinking that maybe all 7" LCDs use identical ribbon cables, because the difference between a Xenarc and LinITX TMR is the reflective layers, not necessarily a difference in the VGA signal coming in. Any thoughts? Has this been done before (one brand cable into another screen)?
    May 2005
    Denmark
    The xenarc cable will fit. It's the same type of cable.
    I have the cable from a Xenarc 700TSV in my TMR monitor. Just check that the wires is not crossed, and the cable is made that way, so one of the sides is stripped to the left, and the other to the right, then it's fine to use.
    // Per.
    Jul 2006
    thanks for the tips. Do you mean your linitx tmr? Also what do you mean by stripped on the left and right side?
    Jul 2006
    went ahead and ordered. confirmed as working. now i just need a replacement cable for the buttons, stupid thing got pinched and now does not work.
  1. Replies: 0
    Last Post: 08-16-2007, 05:13 PM
  2. Where to buy Xenarc ribbon cable
    By dmurray14 in forum General Hardware Discussion
    Last Post: 05-04-2006, 10:06 PM
  3. need replacement ribbon cable + connector
    By keyvan in forum LCD/Display
    Last Post: 04-05-2006, 02:22 AM
  4. FS: Xenarc 700-IDT & 16-ft Cable - BRAND NEW!
    By hd54321 in forum Classified Archive
    Last Post: 09-27-2005, 05:02 PM
  5. Need Xenarc internal cable help!!
    By Tony S in forum LCD/Display
    Last Post: 11-16-2004, 02:54 PM
